Question about Cameras
Lens stuck! hey,today,when i uploaded the pics from my camera,it worked fine.But then,when I was taking a picture,the lens were stuck out,and the screen was turned off. I replaced the batteries,but it doesnt work.I dont drop it or something.Please help me,or you know where fix it and how much does it cost?Thanks alot!
  • Anonymous Nov 15, 2007
    Initiall pictures are extremely bright with horizontal lines on them and now its completely dead, i mean the shuttle it seems not to open anymore,... what the heck do i do??? HELP!!!!
I had a similar problem and I tried all the various combinations of resetting the camera, charging the batteries, plugging in the USB cable etc. After a week or so I powered it off and rapped it against my desk once or twice. Once I turned it back on the lens functioned normally and I am now able to take pictures. This is obviously a solution of last resort but since it looked like even the most basic repair was $90, I decided to give it a shot.
Posted on Nov 05, 2007
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Kodak EasyShare M340 it was working fine earlier today but now when I turn it on the screen is black and when I take a picture it comes out black too, even with flash I can see the saved pics on...
Nov 20, 2010 | Kodak EASYSHARE M340 Digital Camera
Lens got stuck
It sounds like the lens is now out of adjustment and in order for this to be resolved, you will need to take it to a camera repair shop. I have heard good reports about a company called Ritz Camera. Not much else you can do with it unfortunately.
Jun 09, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Over exposed
I just fixed mine. Part of the shutter got stuck, so it was taking in too much light from outside.
You can see if this is the same problem by looking in your lens and zooming in--see if anything looks weird; you should just see a reddish circle in the center of the lens.
I had to take the silver piece off that says "Olympus lens" and whatnot, then turn the camera on and use something ( in my case, a twist-tie) to push the stuck part of the shutter up, through an opening under the removed silver piece. My pictures now look fine as they did before.
To remove the silver piece, just turn it with your fingers counter-clockwise with the camera off.
Hope this helped a little. My warranty is gone anyway so I had nothing to lose. I'd send it back if you still can before doing this.
Apr 27, 2008 | Olympus FE-210 Digital Camera
Olympus FE-210
Hey dramaqueen79,
It sounds like you have internal damage to the camera. I would have it looked at be an authorized service center. If you are fine with the performance of the camera and all you want to do is be able to upload your images you could purchase a card reader(for an xd memory card) that connects to a usb port, and upload your images directly to your computer with the card reader.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 24, 2008 | Olympus FE-210 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Cameras Logo
163 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
