Question about ViewSonic VA721 17" LCD Monitor
Screen dialoge analoge and turns black i have no credit card then i dont know how to pay for asistance
I already own a pc monitor viewsonic 17" VG710s this is happening when i turn the power on the screen becomes black and a blue frame at the center of screen saids analoge then turn black some times itslooks like shadows i think the screen is adjusted in a black range of colors
  • nurse_bettyb May 25, 2009
    I have a pc monitor viewsonic model # VS11435 I have the same problem as above but this is happening when i turn the power on
    the screen after about a few seconds becomes black and a blue frame at the right top of screen of screen says
    analog then turn black. I am so frustrated.
  • 85 Answers
I'm assuming turns black and blue then turns off? First make sure your connectors to your monitor and back of pc are secure. But it sounds like your video card needs to be reseated.
Posted on May 24, 2009
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Sep 10, 2009 | Computers & Internet
Viewsonic vg700b lcd monitor screen turned black
there's an internal hardware problem in your lcd monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
May 21, 2009 | ViewSonic VG700b 17" LCD Monitor
My monitor is black and the green light blinks next to the power button. Why wont it turn on?
Check the screen cable that connected to your Vga card on the pc, it seems it doesnot recognize the pic!
also try to see when you restart your pc did you see any the laoding words or its always black?
let me know wat happen coz this problem has different states , try this and reply me wat happen in order to help you with the right answer.
Best regards
Mar 02, 2009 | ViewSonic A70f 17" CRT Monitor
Problm with viewsonic va712b
It may also be a problem with your video card, I've already seen a problem likewise, try to remove and replug your VGA card and try again, if you can try to plug another screen on your PC and to plug your screen on another PC, then you'll be sure
Nov 05, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Viewsonic E70 - Menu Popup
This is a builti n feature on the monitor of course- not PC driven
A repair is not likely
Buy a nice new Flat screen
Oct 25, 2007 | ViewSonic E70 17" CRT Monitor
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VA721 17" LCD Monitor Logo
241 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
