Question about E-Machines T3958 (827103050974) PC Desktop
Power button is broken
The power button on my emachines t2605 is broken and I cant turn the machine on, how do I fix this?
  • JDTec
    JDTec May 11, 2010
    Take the front bezel off the PC. Inspect the switch. It may have come loose from it's bracket.
    Sergeant:
    Champion:
  • 212 Answers
Open it up and turn it on that way.
Posted on May 24, 2009
Gfdn240gloww power button is pushed in
If it won't pop up, the spring or release may have broken. Full replacement is the only answer if it won't come up.
Jan 18, 2014 | GE GFDN240ELWW Dryer
Power button stuck
If you remove the front panel, you may be able to unstick the power button unless something has broken inside. Some desktops are prone to having this problem
Feb 06, 2013 | E-Machines eMachines Desktop PC
I have an Emachine W6409 Desktop, it was turned off(proper shut down) after an hour or so, pressed the on button, nothing happened, power supply was replaced, attempted to turn on and again nothing...
It sounds like you dont have the motherboard/case wiring input properly, without a specific diagram of your computer, i cant really tell you what to plug in, but your computer could have come with the correct wiring guide.
Feb 05, 2011 | E-Machines eMachines Desktop PC
The fan keeps running and the blue light around the power button doesnt turn on
There might be something wrong with the connection between the light to your main board. You can open the chase and see whether there are broken wiring between the front pane of your machine and some ports on your main board.
Jul 05, 2010 | E-Machines eMachines Desktop PC
Start-up problem with emachine 366i
Replace the power supply - but before that - remove every card in the machine and remove the ram too - clean the end of the ram with a pencil eraser - reinstall.
Clean the rest of the cards with a pencil eraser and reinstall.
Blow all the dust from the machine with a can of AIR - get the power supply and fans real good - put it back together and if it works - fine - if not - replace the power supply.
Apr 30, 2010 | eMachines etower 366is PC Desktop
Itt urns on but it stays on the emachine bootup
We can only try for a power drain for this issue,
all you have to do is unplug the power cable from the computer and battery too, then press and hold the power button for 40sec( without battery and power chord), then connect the power cable back. then try to turn on your computer,
Hope this will work!!!
Still if you are facing the issue then you need to consutl with a local tech because it might be the issue with the hardware
Mar 02, 2010 | E-Machines M5414 Notebook
My Acer emachine E627 the touchpad doesn`t work. what do?
Mine stopped working too, and it turns out to be that button to the left of the power button that disabled it. Check that...if the
light is on the mouse pad is lock... Hope it helps!
Jan 22, 2010 | Acer eMachines 520-2890 Notebook
Replaced mother board, forgot where power switch plugs into
you can look for the power switch terminal by its label.like PW for power button and PLED for power led.reset is RS.
May 20, 2009 | E-Machines eMachines Desktop PC
We have a emachine 17 widescreen monitor E17T6WTFT. it is plugged in but it will not turn on. Have only had it for 6days
We could go through many troubleshooting procedures but if it's only 6 days old take it back and get a new one. There's no reason you should try to fix their problem.
The only obvious thing to check is that the cables are seated, secure and functional. Also, when you press the power button, do you get any light around the power button at all? If so, what color is it?
Jan 11, 2009 | E-Machines eMachines Monitor E15T4
Emachines T2482
Could be a video card failure or a cable problem. This could also happen because the motherboard failed if you have integrated video. Unfortunately your going to have a tech onsite to repair the issue. That is, unless you want to install your own video card which would probably fix the issue.
Jul 08, 2008 | E-Machines eMachines Refurbished EMA...
E-Machines T3958 (827103050974) PC Desktop Logo
138 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
