Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Ice maker working but water is not dispensing
Our ice maker is working but no water is coming out of the dispensor.
    Sergeant:
    Champion:
  • 212 Answers
Check your hoses. They probably are plugged
Posted on May 24, 2009
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Hello. My side by side refrigerator model MSD2434GE, serial no 11874215CG , I can not get water from the water dispensor, I ice dispensor works fine, I have tried pressing the lock three times but still...
There is valve at the back of the ice maker unit.This valve is the one unit with twin inlet.From one inlet the water enters the ice maker and from other inlet the water enters the water dispenser.so in that valve the ice maker side is working but water dispenser side is not working.Or the ice is got clogged/ over frosted in the water dispenser entering pipe.either the valve needs top be replaced or the water dispenser pipe needs to be checked.Calling service person is advisable.He will just check and confirm what is the issue, the water valve or the over frost build up in the water dispenser tube.and do as required to solve the issue/.If case if the water valve needs to be replaced then cost of water valve is approx $40.------------- this will help.Thanks.Helpmech.
May 29, 2011 | Maytag Refrigerators
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water not coming out of dispensor
two problem one water vale are the line were water come out is frozen the water splashes back and line freezes are water vale leakes
Jun 01, 2009 | Refrigerators
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Mar 08, 2008 | Refrigerators
No ice or water from dispensers
Womers, make sure there is not a lock-out on the dispensor panel. If there is, hold it in for 5 seconds and see if the dispensors come alive. Because both water and ice are not working, I would think you have a dispenser board issue. Catriver..post back.
Sep 26, 2006 | Whirlpool GS5SHAXN Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
263 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
