Question about Milwaukee 6232-6 Variable Speed Deep Cut Portable Bandsaw Kit
Want to know where to get owners manual
Need to know where to get owners manual for Milwaukee deep cut band saw...6232-6 SER # 678J402490762 Cat # 6230
  • charlgush May 24, 2009
    redbeard, I'm going to do that right now !! Thank You very much, I owe You big time !!
    Chuck Gushue.....Philly, Pa.
    Charlgush@aol.com
    President:
  • 957 Answers
You can go to Milwakeetool.com and down load the manual for your tool.
Posted on May 24, 2009
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
Mar 26, 2014 | Milwaukee 6238 Deep Cut Portable Band Saw...
Jammed my 6230 bandsaw during a cut and now it won't start. Are their fuses I can replace?
Go to Milwaukee Tool website and try to check if you can download a manual or electrical diagram there. You can call or email them. Check the motor capacitor.
Are you using an old or new band saw blade? If it's old/dull, try different blade. If it's new, the weld might be really bad. Old Blade and Bad weld can cause the blade to jump off. I purchased band saw blades on www.sawblade.com . Great quality blades; they have porta band blades. Call them.
Oct 23, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Blade is not straight is thier an ajustment
What do you mean? Is the blade itself is not straight when you install it or the blade is not cutting straight?
Jan 07, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
How to take apart the gear box on a milwaukee deep cut band saw 6230n
unplug tool, remove the handle assembly making note of the wiring, turn the tool over and remove the rear pulley under that you will find 2 torx drive screws remove them and then gently tap the housing to start to remove the gear assembly. remove the 4 bolts holding the gearcase to the motor housing and pull apart, when apart you can finish tapping and the lower gear along with the top one will "jump out" Let me know if you still have any problems
Jan 24, 2011 | Milwaukee Tool Milwaukee 6230N Deep Cut...
What is the part # for the belt that drives the blade?
You can download manuals and parts lists from http://www.milwaukeetool.com/
Nov 16, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
I need a wiring diagram for Milwaukee 6230 band saw
go to "milwaukeetool.com" and with your model and serial (just the first few number) you can download a wiring schematic that is in complete detail for this tool. Let me know if you need more assistance.
Apr 06, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
I just bought a used Milwaukee 6230 metal portable band saw and would like to get the manual and parts list for it any suggestions?
Hi, This is a link for the parts diagram. Sorry I can't help with the manual. Scroll down to just about half way for your model.
Hope this helps.
toolpartsdirect.com/milwaukee/milwaukee-52.html
Aug 17, 2009 | Milwaukee Deep Cut Portable Band Saw W/...
Need manual for Milw. Portaband 6232-6 that's what's on the case
Go to Milwaukeetool.com and under the service portion select the download manual area and then type in the model number 6232. I haven't heard of the -6 but they have numerous schematics for this tool according to the serial number. If you are looking for a part in particular let me know. I worked for them for 16 years and will try and help. Good luck and if I have helped you would you please rate this solution accordingly and thank you.
May 24, 2009 | Milwaukee 6232-6 Variable Speed Deep Cut...
New switch
OK make a drawing of the back of the switch, you should see 5 openings 2 already with wires in them. From back upper left is black supplied with switch upper right is yellow from the field middle is also a black supplied with switch lower left is black from the power cord and lower right is white from the power cord. Let me know is any more problems
Jan 21, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Milwaukee 6232-6 Variable Speed Deep Cut Portable Bandsaw Kit Logo
171 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
