Question about Philips 60PP9352 60" Rear Projection Television
Chirping Sound / Overloaded power supply
I have a Philips 60" plasma TV model #60pp9352. The TV initially had convergence problems and both the vertical and horizontal convergence chips and the 12 convergence resistors were replaced. After installation the TV work great for about 2 hour, when all of a sudden the TV turned off. The TV now make a chirping sounds and I get no picture and no sound. I have checked the AC Input board, Standby supply, which are both giving me the right voltages. The Full power supply is oscillating on and off. The Full power supply gives the correct voltages when jumper 9000 from the Horizontal Output circuit is removed. I have checked and changed the HOT transistor (7801) in the Horizontal Output circuit, since it was bad, but I still get the chirping sound.
  • keiji May 24, 2009
    How do I test the HVG? What am I looking for.
  • 110 Answers
Check the HVG #5904
Posted on May 24, 2009
It started with color convergence problems unable to ajust manuely then stopped turning on only makes a chirping sound when plugged in.
nfmstorm,
The chirping signifies that your switch mode power supply is being overloaded. You probably have a shorted horizontal output transistor. I have a tip at http://www.fixya.com/support/r4425451-when_you_turn_your_television_on_and_get which should help with the troubleshooting process and also the best places to get parts.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 20, 2010 | Philips 60PW9363 60" Rear Projection...
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
Turn the TV on and it just make a chirping sound no picture
Without examing the set. IN general as a techs when they hear chirping noise is an indication of what is know as a Bad Flyback transformer; You may possibly have a shorted Horizontal Output Transistor or both that will need replaceing.
Apr 24, 2009 | Philips 60PP9352 60" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Convergence problem with Philips 60PP9352
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
324 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
