Question about Panasonic NN-H504WF Microwave Oven
My new microwave is completely dead
Panasonic model #NN-H614........I was diagnosing an electrical problem at the breaker panel with the neutral disconnected and momentarily I switched on the main breaker.  In the kitchen I heard a buzz and quickly disconnected power.  Trying to locate what happened I could smell something burnt through the side vent of the microwave. And I saw that it was dead, no display on the LCD.  The receptacle it was plugged into worked with other appliances, so, my question is, with the spike of voltage it got zapped with, probably 240 volts, what burned out?  Does this model have a fuse (I hope) that could have blown, or is it a transformer or a magnetron in your experience?  Thanks so much in advance for your evaluation!
  • marksal May 24, 2009
    No, the breaker didn't trip.  Are you positive there is no fuse?  I found a fuse listed for a similar Panasonic model, NNH664WF at AMI Resources
  • Dan Todd May 11, 2010
    So when you turned the main breaker off and disconnected the neutral, and turned it back on, the breaker for the microwave didn't trip when you heard the buzzing sound?
    That breaker is supposed to trip when you have a dead short like that. There is no fuse inside the microwave. It sounds to me like the main power transformer is fried, especially if the 120v side won't even run the lights.
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
My Panasonic Dimension 4 microwave/convection oven (NE9870) is dead. It was running, produced a small popping sound and is now completely dark. I've tried alternate electrical outlets and there...
Ken,
Usually there is an internal fuse and that is probably your problem. You will need to take off the outside cover of your microwave and then look where the power cord goes into the back of the unit. Look for the black wire coming out of the power cord and follow it. It should take you to the fuse. Hope this helps!
Dec 16, 2014 | Panasonic NN-T888S Convection/Microwave...
Microwave oven dead
Check the fuse in the microwave it is probably open, unplug and remove the top, follow the leads from the keyboard to the circuit board, look for a silver rectangular capacitor, short out the two pins to remove any high voltage, now look for a small fuse that is clipped in, pop it out and check if open, replace with same current rating. The door switches in most cases cause the fuse to blow, normally one switch is defective.
Mar 17, 2012 | Panasonic Microwave Ovens
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Mar 12, 2012 | Panasonic Microwave Ovens
Pushing the start button trips the breaker. All functions seems to work, fan, clock etc but it just started as soon as you push start it trips the breaker. Control panel/board seems fine no burn marks.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Genius/Prestige/model.NN-P295SF
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Service manual below, troubleshoot with that. http://www.eserviceinfo.com/downloadsm/5734/PANASONIC_NN-K652.html
May 04, 2010 | Panasonic NN-P295SF Microwave Oven
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
Panasonic 1250 watt microwave approx 5 yr old. the oven is completely dead. checked in other outlets. no power to oven
something burned out, has there been a thunderstorm lately?
if you get a new one, plug it into a surge protector.
Jul 16, 2009 | Panasonic NN-H504WF Microwave Oven
Voltage in home down when start microwave
Either the outlet for the microwave is not on its own breaker (which it always should be) or there is a loose screw connection or oxidation in the circuit breaker panel.
If the bad connection is on the neutral wire, this can create a dangerous condition.
You should measure (or have a pro measure) your voltage in various outlet s in the home.
If you have low voltage on some and high on others, you have a faulty neutral.
This can be serious. It should be checked.
Aug 11, 2008 | Panasonic NN-S954WF Microwave Oven
Panasonic NN-H504WF Microwave Oven Logo
127 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
