Question about Brother MFC-5840CN All-In-One InkJet Printer
I can't Scan 8 1/2 by 14. It cuts the scan to that of a regular paper. I can fax by 8 1/2 by 14 and it comes out alright. how i do the set up. I used the set up in the scan but it did not help.
  • firefighterb Dec 18, 2007
    trying to set up how to scan not found in the manuel
    New Friend:
    Problem Solver:
  • 7 Answers
I also had problems scanning legal size documents with a Brother MFC-7440N. The documents would scan but would not come out complete. A large portion of the text would always be left out and only an image of the size of regular page size would come out. I knew it had to be something with the settings, so after experimenting with my MFC-7440N I came to the conclusion that I was not going to find the solution on the actual machine. I had a "Hunch" that I would find my solution by connecting the printer to my laptop computer and use the software that came with it. After a couple of minutes I was able to scan Legal Size documents in a breeze... I should of done this months ago. All scanned docs came out in full size.
So I took some screen shots to post them up here to let everyone know how to scan legal size documents since I noticed that people are having trouble just like I did. With this instructions you will also be able to scan any available size documents with a Brother MFC-7440N. I will also guide you step by step. After step 4 the remainder steps are OPTIONAL unless you need to change the color or picture file types. Okay, here we go!
Step 1.
Make sure your MFC-7440N is connected to your computer and the computer has the software installed that came with the printer.
Place the Legal Sized documents/papers that you want to scan on the Paper Feeder Scanner located on the most upper area of the machine.
Step 2. On your computer, go to START then to DEVICES and PRINTERS, or CONTROL PANEL then DEVICES and PRINTERS. Locate the icon of your MFC-7440N. If its not your DEFAULT printer make it the default one. Then RIGHT Click on the icon. A menu will pop open. Locate START SCAN and click it.
Step 3. A small window will open that will give you various options to scan a multitude of sizes and different settings. Locate where it says SOURCE. The default setting might be FLATBED meaning the flatbed scanner of your machine. Click the drop down menu and select FEEDER. By selecting the feeder option your computer will tell your machine to use the automatic paper scanner located on the most upper area of your machine.
Step 4. Locate PAPER SIZE. Click on the drop down menu and then select Legal 8.5 x 14 inches (216 x 356mm).
If your documents are already located in the feeder you can now go ahead and click SCAN and your documents will begin to scan.
Your scanned documents will be saved in a file folder in your computer and that file will pop open for your convenience once all documents are scanned.
If you need to change COLOR or Black and White setting plus Picture File Types such as Jpeg or Tiff just click on their respective drop down menu before clicking SCAN.Here are some pictures to help me illustrate it.
I hope you find this helpful.
Thank You!
Visit me at: at I can't Scan 8 1/2 by 14 - 92c85b21-a89d-4f9a-bf67-a96f103f2c15.jpeg da5aa6de-6531-4fb6-9f91-3a1b503ac89c.jpeg 36e97075-1229-4d28-b14c-e7371ad26589.jpeg 4203c1e5-8b35-4dc9-a802-65652251f028.jpeg
Posted on Oct 15, 2014
The default scan size is set to A4/Letter so you need to use the Scanner Resolution Improvement Tool to change to Legal size.
If you installed the complete package it should be in the MFC program group.
Or you can download it from Brother Solutions Center:
Seasons Greetings
Brother D
Posted on Dec 18, 2007
How do I set up on my printer to connect fax
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Feb 18, 2015 | Samsung Xpress SL-C460FW Laser...
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
May 31, 2011 | Brother 5750E Fax
Cant send nor receive faxes
dear sir,kindly follow the below instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Receiving faxes alright, people receiving faxes from us are getting an all black page
Your document scanner has died. Meaning that the row of LED's that light up to scan the documents you are trying to fax are not lighting up. The result is a scanned document that is read as all black. Make a will get a black sheet because the same process is used to scan the document when making copies.
It might be time for a new fax machine as these machines have become so cheap to buy new that I doubt you could get this machine repaired for what you can just buy a new one for.
Good Luck and Thank You for using Fixya.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Would not receive or fax papers because "out of memory"
well, you can either cut down on the amount of faxes that you do at one time, or you can go to page 36 of owners manual and change your settings to fax in "real time". that way, it will not fill up your memory, however, the adf will not scan them fast and spit them out. it will be a slower process in that respect. it won't fax slower, just the scanning part will be slower. i hope i explained it clearly enough.
Feb 26, 2009 | Brother MFC-8460N All-In-One Printer
Hp fax/scanner # 6110
Hi Judy,
The only document I found at that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
Have a look at the suggestions on that web page and see if anything there helps. Post back you results and good luck.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
I want to scan then send instead of scanning whilst sending
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Feb 07, 2008 | Canon FAX-L200 Plain Paper Laser
Paper jams when trying to send fax (original goes in short way then jams) unit has had little use it establishes connection and then stops and jams when commencing scan
look in paper path(scanner compartment were paper feeds) to ensure there is no pieces of small paper or foriegn items in this area preventing paper from going all the way through if this fails clean the feed roller in document scan area with a micrfiber cloth moistened with rubbing alcohol
Jan 13, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother MFC-5840CN All-In-One InkJet Printer Logo
299 people viewed this question
James Cagle
James Cagle
Jim Keysor
