Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
Problem with Video on motherboard Gygabyte 8VM533M-RZ
I need to chance the configuration of memory video in my computer, i need to change from 32 MB to another quantity more high than this, how i can do that, because i cannot see in the BIOS the configuration of video,and i only see this quantity when i enter on the properties of the screen.
I need to konw too if i can buy an AGP Video Card 8X, because supposedly the manual says that the motherboard only support AGP VIDEO CARD of 4x(1.5V) is important the velocity of 4X or 8X in this case?
    Novelist:
  • 118 Answers
You should be able to find all you need here in the manual for your board. However, it would most likely benefit you the most to aquire a new 4X AGP video card and install that, bypassing the onboard video altogether.
good luck
tony
http://download.gigabyte.ru/manual/motherboard_manual_8vm533m-rz_e.pdf
Posted on May 24, 2009
  • 34 Answers
The answer is a definite YES. By definition of the AGP set standard, 8x gear absolutely must be backward compatible to 4x.
Any 8x card in 4x-only mainbaord, or 4x AGP card in 8x capable motherboard must and most definitely will work.
How to install windows 7 32 bit in my gigabyte 8vm533m rz motherboard
You need the installation DVD, or download the ISO and copy to a bootable USB pen drive.
Boot from the DVD or pen drive and follow the on screen instructions.
You will need the licence key to activate the software.
Nov 13, 2013 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Want video drivers
Is you are using the video of the motherboard then I would get an update on the setup disk that came with your motherboard. If you have a graphic card plug in on the motherboard then I would get the driver from the manufacture web site of the graphic card.
Mar 30, 2012 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I have not any setup of sound driver
Hi, you can download a sounddriver here:
http://ee.gigabyte.com/products/page/mb/8vm533m-rz/download/
The driver may need to be unziped before installation.
Hope this was helpfull.
Aug 19, 2011 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Driver de audio
http://www.gigabyte.lv/products/page/mb/7vt600-rz/download/
Jan 25, 2011 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Display
Normal 0
If you are looking for the video driver then -
You can download the drivers from Gigabyte WEB support site, select your model motherboard to download :-
http://www.gigabyte.com/support-downloads/support-downloads.aspx
Oct 10, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
The motherboard power starts but did not gives a boost and gives me a long beep
Your motherboard does not have a problem and the long beep that out in your computer is the problem about your memory of the motherboard. Try to remove your memory on the motherboard and clean their pin. To clean the pin of the memory, just wipe a pencil eraser or rubber. After that just insert it back to the motherboard and try to on your computer again. If the long beep also comes out, try to change your memory on the motherboard because its maybe your memory was damage.
May 25, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Compatible agp card for 8vm533m-rz motherboard
This board only has a 4X AGP slot so any AGP video card of 4X will do recommend 256MB or more if you can get it
Sep 25, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Not booting
you have a motherboard system fault.
1) try different memory sticks
2) check if hard drive wired in correctly
the broad ribbon cable to it should have the stripe next the the power 4 pin plug
3) try a different video card
there are other things to try but try these first
Jul 20, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
No signal on monitor
The beeps you heard, 1 long two short is the bios telling you that there is a problem with your video card. Normally you would remove & reseat it. Not the case with the intergrated video. When you added an AGP card you should have been able to get video. All video is controlled by the intergrated video controller. If your sure the radeon works than all that is left is the mb controller which can't be fixed. There is a slim chance you might get a PCI video card to work. Link to your board:
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1766
Jan 13, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
No display
try a video card and turn off the onboard display card.
Dec 04, 2007 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
197 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
