Question about NAD T760
No signal from sub connected to NAD T760 in test mode.
Energy Encore 8 Subwoofer connected to NAD T760 sub woofer input using single RCA to RCA interconnect cable. When the NAD is turned on I get a woomf from the subwoofer so the sub seems to be receiving signal but it does not operate in test mode nor in normal pro logic or ears. Cant think of what has changed in my set-up to create recent problem.
Using preset 1 with all speakers large and sub-woofer on. Tried preset 2 to no avail.
Any ideas.
  • 1 more comment
  • ahmorgan May 24, 2009
    Thanks I tried your suggestion of using the front pre-out from the receiver. No signal. The sub does not have an on/off switch. It does have a blue light which comes on intermittently I think while its waiting for a low signal from the amp. The funny thing is when I touch the end of the interconnect cable which goes into the amp I get feedback in the sub. Also when it touches the outside of the amplifer around the pre out sub woofer connection on the amp I get strong feedback in the sub.
    What if I use the tape out?
  • ahmorgan May 27, 2009
    I did plug the sub in through the tape out and got a fairly strong signal through the sub so the problem points to the bank of audio pre-out connections on the T760. (Confirmed earlier by trying the sub in the pre-out front connections) Next step I believe would be to take the amp in for repair.
    Potential problem might be the solder connections on the board as these do not take kindly to heat.
    Thanks for your help.
    Did try plugging in the Encore 8 subwoofer through the tape 1 and got a strong signal from the sub so the problem points to the pre-out on the T760. Normally the sub is plugged in through the pre-out sub. This might have been confirmed when I tried the sub through the pre-out front which also provided no signal.
    Next step is to take in for repair. suspect the problem may lie with the solder connections on the board as the T760 is prone to overheating. Thanks for your help on this.
    President:
  • 1,114 Answers
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
Posted on May 24, 2009
  • Frank Fulton
    Frank Fulton May 25, 2009
    Interesting that your main out is not functioning... You can use Tape to test just make sure "monitor" is on. The feedback at least lets you know your amp and sub are ok. You can use any product that has an output to test to make sure the sub is triggering correctly. Check your Pre-out settings on the receiver as well if possible, generally the front pre out is always on. I'm wishing I could be in front of it now as it's always easier that way! Interesting note: when you have headphones plugged in, sub-out is off. It also does not work in "test" mode. If it's connected to a TV; Get into the receiver OSD setup menu put a cd on w/some bass and check your setting, your adjustment is from -10 to +10. That's a big spread and may be the issue. If you don't have the manual, http://nadelectronics.com/img/manual/NAD... Hope this helps some more.
New sony receiver str-dh740 has 2 RCA plugs for sub woofer. How do I connect to psw350
only use one of the outputs from the rear of the str-dh740. and use a rca "y" adapter where you plug it into the subwoofer so that both of the inputs on the sub are getting a signal.
May 11, 2014 | Polk Audio PSW350 Subwoofer
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Mar 05, 2010 | NAD T770 Receiver
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
May 16, 2009 | Kenwood Audio Players & Recorders
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
NAD T760 Logo
672 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
