Question about Dryers
Push button on dryer will not start
Dryer will come on but when i push the button it will not start
    President:
  • 1,136 Answers
Hi, is this a whirlpool dryer? Try this, Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on May 24, 2009
START SWITCH BROKEN
try joining both wires on door push switch then push to start,if it starts then have to change push button on door,or fuse inside blown
Apr 08, 2014 | Maytag Neptune MDG5500AW Gas Dryer
When I push the "push to start" button (knob) on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 14, 2011 | Kenmore Dryers
When you push the "push to start" button, the
I would say change your Start button should take care of the problem.
FIRST Always unplug the Dryer before doing any work on it.
Good Luck
Dec 26, 2010 | Kenmore 62982 Electric Dryer
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
Dryer won't turn
The problem is likely a slipping dryer belt. The belt tensioner is not working or the belt needs replacing.
Apr 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
