Washer wont go to rinse cycle or past it
Earlier the washer had nothing but hot water coming out of it, never had that problem before. My husband fixed it and now it will not go past the rinse cycle.
  • kristin_r894 May 24, 2009
    I can't rinse with any water. Nothing happens once it gets to rinse. Everything is fine until then.
    Now its just cold water.
    President:
  • 1,136 Answers
Hi, It sounds like the cold water side is still an issue. Can you rinse with hot/warm water or only cold?
Please let me know so thatI can assist you further.
Thanks
Vic
Posted on May 24, 2009
  • Victor
    Victor May 24, 2009
    If you return to the wash cycle, do you get both hot and cold water?
  • Victor
    Victor May 24, 2009
    Reverse the hoses on the back and then see if you get just hot water. While you have the hoses off, ckeck and see if there is anything plugging the screens inside the mixer inlet valve. I believe the inlet valve has gone bad on one side.
    Once you get the hoses back on, leave the water turned off but turn the washer on the wash cycle. Set the temp to cold and listenfor a faint hum. Then turn to hot and listen. If both sides are humming and the screens are clean, you should get water.
    Please let me know with you model # and I can get you the part # for the inlet mixer valve.
    Vic
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
My washing machine mentioned above wont drain the water or preform the spin cycle process once it gets to the usual 7 minute mark. No leakage, just not drain or spin. How can I fix it?
TIMER
Mar 26, 2015 | Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer will not rinse on the white cycle. is it the timer?
you must know that because it sets there and dose nothing???if so it has to do with water[its calling for it and its not coming so it keeps waiting,cant move on till sattifies the water level switch].set timer at start of load and check water setting temps .dose cold come out when set cold only also same hot.ihope thats a bit of help.God bless ,tom
Jan 04, 2009 | Whirlpool GSC9455 Top Load Washer
Washer wont rinse
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
Aug 04, 2008 | Maytag MAH2400A Front Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
