Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
31cc Ryobi weed eater engine will start, then stall shortly after
Engine runs with full choke on, but stalls after you move the choke lever to partial on position.
    Sergeant:
  • 384 Answers
You need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
Posted on May 24, 2009
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi ry3002a weed trimmer won't idle. It shuts off as-soon-as I move the lever to run position. I disassemble and clean the carburetor but no luck. Any suggestion?
Run at 1/2 choke rev the engine & count to 10 showly. The engine should now be warm enough. If it still stalls, turn up the low idle screw.
Aug 24, 2015 | Ryobi Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Poulan pro ppb350 weed trimmer stalls when choke is open
    -After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
    Because the engine need more air to burn the gas.
    Good Luck
    mai
    Jun 06, 2014 | Garden
    Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
    You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
    May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
    The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
    Jul 09, 2010 | Garden
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Ryobi weed eater runs at full choke, but stalls when choke is turned to run position
    does it blow out alot of blue or dark exhaust? if so adjust screw on carberator as it maybe be running rich, if this doesnt work have the switch checked for malfunctioning
    May 30, 2010 | Ryobi 15" Electric Factory Reconditioned...
    Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
    315 people viewed this question
    Top Black & Decker Garden Experts
    Jim Parker
    Jim Parker
    Nick Olsen
    Simon Elder
    Level 1 Expert
    Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
