Question about Garden
John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
    Problem Solver:
  • 11 Answers
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
Does the John Deere LX172 mower have an electric clutch and if so how do I operate it. I can't get my tractor to move.
Hi Bill, you electric clutch only engages your pto. The clutch for the Transmission just releases tension on an idler for the drive belt. Do you still have spring resistance on the clutch pedal?
Jan 21, 2017 | John Deere Garden
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
I have a 1999 John Deere LT-133 when I put it in any gear or try to engage the blade the engine won't stay running. Do you have any solutions for this?
sounds like the safety switch under the seat may be bad. unhook and / or bypass the switch. if this fixes the problem then replace the switch. hope this helps you
Aug 16, 2011 | John Deere Garden
I have a John Deere LT 133 lawn mower, when I release the clutch/brake pedal the motor will will not continue to run.
There will be a faulty safety switch somewhere. Most likely the one on the seat. Regards Phil
Apr 10, 2011 | John Deere Garden
John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Oct 02, 2009 | John Deere Garden
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
Garden Logo
846 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
