Question about Brother MFC 420CN All-In-One InkJet Printer
Error message My printer won't print it keeps coming up with a error message of unable to clean. Please help
  • pastapete Oct 20, 2007
    now the error message is unable to print.
  • johnny7214 Feb 27, 2008
    original prob was no ink i repalced ink then got paper jam the the printer started making funny noise took it apart found the print head was not on the rails correctly so i put it back together. then i got it to where it sounded like it was printing but it would only print color no black took it apart again now it is giveing me an unable to print message no error code just says check the trouble shooting and maintanace sections in my book dont see any thing that helps
I can print directly from my DCP-115C printer,but get error signs when trying to print from my Mac. computer.
Posted on Feb 24, 2008
  • Brother Master
  • 1,113 Answers
Does it say an error after "unable to print",what lights? are all inks good?, is there any bits of torn paper inside where head and carriage side up and down?
Posted on Oct 20, 2007
2 Suggested Answers
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: Unable to print, unable to int, unable to clean
unable to clean is the error 46. You have to change the waistinktank and to reset the error code: Buy/order a new waistinktank from a service partner (see brother homepage). Open the printer (use pictures to know how to): http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c The waistinktank (ALTTINTENTANK) is the plasticcover with the white felt in it (should be gray/black now) and the two tubes (gray/white). Unplug the tubes and change it to the new one. Reassemble the printer. After power up press menu then start mono (B/W) then 4 times arrow-up: maintenance should be displayed and printer beeps with flashing buttons. Press 8 and 0 (zero). Press severaltimes (about 15-20) start mono (b/w) until purge (Nummer is about 6425) is displayed. Press 2 7 8 3. Purge is 0000. press stop. press 99. machine comes up again. thats it. BTW: YOu cant clean the waistinktank. Buy/order a new one! If you reset the purgecount without changing the waistinktank ink will flow into the machine!!!
Posted on Sep 18, 2007
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Brother MFC-440CN InkJet Printer
Brother mfc5860cn has error message print unable - 4F
Hi there
Please try this.
May 03, 2009 | Brother MFC-5860CN InkJet Printer
Unable to print 4F error message
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Jan 14, 2009 | Brother MultiFunction Center MFC-440CN...
Sep 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
241 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
