Question about Maytag Neptune MDG5500AW Gas Dryer
Stops heatinng My Maytag MDG5500AAW starts to heat then stops. Sometimes I can switch between senor dry and timed drying and it'll start to dry for a few minutes but then stops again.
  • 331 Answers
Ithis sounds like the ignitor glow bar might going out. take the door off and remove the from plate. you need to get on your knees to see this. put a peice of tape on the door interlock. turn it on. the ignitor glow bar should be red hot. This ignites the gas. I suspect that it is not going on at all. and the tumbling in the unit airates the clothes making it seem like its on. Remember to take the door off first. this website has the ignitor you need
http://www.repairclinic.com/Maytag-Dryer-Parts?s=t-starter-%3d%3db4a8c249
If this helped please rank me
Posted on May 24, 2009
    President:
  • 1,136 Answers
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
Hello when I catch my maytag of gas it activates and warms up but in second she goes out treats many things but she follows equal
Posted on May 29, 2009
How do I reset the code.the lights are lit 4 hour delay, rinse only steam clean.
THIS DISHWASHER WAS RECALLED BY MAYTAG.. You might want to call them to see if it is still covered.
If already repaired you might try:
Normal - heated dry - normal - heated dry. then try to use the machine.
Oct 19, 2015 | Maytag MDB7809AWB - MaytagR JetcleanR Plus...
Comercial maytag dryer will not shut off. tried replacing timer. heats up but will not shut offf
When a dryer heats but the timer does not advance especially on the auto. dry setting (not timed dry) the problem is usually always a airflow problem. What needs to be checked is for lint build up in the blower housing, a blocked or restricted. Also on Maytag dryers a problem sometimes is that the blower wheel drive hub where it connects to the motor is stripped so the blower wheel cant move air,typically if that is the case a rumbling will be heard when dryer starts and once again when the dryer stops a rumblimng noise will be heard.
GENE
Sep 23, 2011 | Maytag Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
The gas dryer heats then does not heat. The sensor says 99 minutes to dry close. Tried it on timed heat and it dries then stops drying. Sometimes shutting off completely!
Hello,Cheack to make sure your venting is clean and clear..If its blocked the safty thermostat will shut the heat down to prevent overheating.. If the vent is clean i would check the coils.When they start to fail it will heat then not cycle back on..
Jun 18, 2011 | Maytag Neptune MDG5500AW Gas Dryer
MODEL PYGT444AWW GAS DRYER LITES UP OK BUT SHUTS DOWN HEAT TO SOON ALONG TIME TO DRY
there is a saftey relay that might be bad and needs replacing.. this is there for keeping dryer from starting a fire or over heateng.. when the dryer start heating the saftey switch is on and once it stops heating the switch is open and and will not dry.. it could be a heating element once it gets hot it expands and will not heat..
Mar 25, 2010 | Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune MDG5500AW Gas Dryer Logo
347 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
