Question about Dell Latitude D800 Notebook
The command to create an MS-DOS boot partition to set up Windows
At first I have a new Dell laptop with windows NT in it then I attempted to upgrade to windows XP without succes. After I used the installation disk to explore further how to upgrade but instead I never was able to reboot to windows NT anymore. Now I am trying to boot it with Win95 and the message given is (you will need to create an MS-DOS boot partition to set up Windows)
  • 85 Answers
The reason u cant load win 95 is cause NT uses NTFS file system while win 95 uses FAT file system totally different format.
Make a 95/98 boot disk and then go download ranish partition manager and put it on the boot disk. Once it loads up to a command prompt type part Typing part will execute the file on the disk to load up the manager. Here u can delete the NTFS and make a fat 32 or fat 16 and format the Hard drive. After doing so turn off pc and put in the system cd u want to install.
Posted on May 24, 2009
  • 155 Answers
You need to boot from the XP cd, and from there you may be able to do the installation. To set the laptop to boot from the CD you need to configure the BIOS by pressing F2 while in the Dell progress bar.
  • 111 Answers
I want to format my c drive with the help of Dos command prompt , installed win 7 ultimate.
Formatting hard drive When booting from a Windows installation CD select the option to install Windows then you (can either delete the existing partition/s then create a new partition then you) can format the hard disk. After formatting the hard disk you can abort the Windows installation if you do not want proceed to install Windows.
You should be able to use the Windows 7 installation CD to delete the existing partition, create a new partition and format the new partition and then install Windows 7.
Apr 03, 2013 | Computers & Internet
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
HOW DO I GET INTO MS-DOS PROMT
  1. Click Start.
  2. Click Run.
  3. Type cmd or command and press enter.
Jan 18, 2009 | Compaq Presario C700T Notebook
BOOTMGR is missing
i have a problem when my external drive is in the usb and i start my laptop it says bootmgr is missing how can i sort this problem as i have to take it out of the usb plug to get my laptop working the i plug the external drive back in and it works,
Dec 17, 2007 | Computers & Internet
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Dell Latitude D800 Notebook Logo
264 people viewed this question
Alun Cox
