Question about GE J Series 20.6 cu. ft. Top Freezer No-Frost Refrigerator TBX21JABWW
Only freezer works
We moved this refrigerator to the garage. The move was smooth although there was some bumping and shaking but nothing major. We plugged it in again and now only the freezer works. The refrigerator (bottom part) does not work and the appliance light does not work when the door is opened
  • carlosal May 24, 2009
    We did tilt the unit a couple of times and a black liquid came out. Not much. The fan in the freezer is working and I tried a new appliance bulb but it did not work.
    We moved it this afternoon. It is in the garage now and the freezer is cooling but nothing is happening in the lower section. Thanks for your help. I will check the freezer tomorrow .
    President:
  • 1,136 Answers
Hi, Check and see if the fan in the freezer is running. The light bulb might have loosened or broke while moving. Try and tighten it or remove it and try it in a lamp.
If the fan is running, check control settings. They should both be set at whatever is half of the dial settings.
It might take up to 24 hours if it had been shut off for any lenght of time.
Please let me know if I have helped at all or if I can assist you further.
Thanks
Vic
Posted on May 24, 2009
  • Victor
    Victor May 24, 2009
    The black liquid might have been old water in the drain pan (we hope). If it was oil from the compressor, that means a leak and you would have no cooling at all. You can remove the rear panel inside the freezer and see if it has an even layer of frost on it. If only a portion of the coils are frosting, you might have a compressor going bad. How long ago was it moved and been running where it is now?
  • Victor
    Victor May 24, 2009
    Ok, and if I can help further, please let me know. The freezer needs to be 0 to 5 above.
    Vic
2 Suggested Answers
  • 103 Answers
SOURCE: Only freezer works
Hi: When you plugged it in how long did it take for the bottom to warm? If it was a week or two it might be your defrost heater(frost builds where it shouldn't). It's just a wire in a glass tube like a light bulb, and will be fragile after years of service. When the freezer works and the fresh food dosn't it means there is no circulation between the two. Frost will build up where you don't see it, and it's where the air channel is between the freezer and the fresh food. When moving a ref. it usually is the def. heater. The light bulb is isolated from this circuit so it may just be the bulb (the filament got shook) or the switch. Good luck Jeff
Posted on May 31, 2009
I have a whirlpool chest freezer and the warning light has come on it was stored in the garage but was working fine,then moved into the house.the compressor kicks in for about 10 seconds then cuts out
a refrigerant line may have been damaged in the move, loss of refrigerant or a kinked line has stopped the compressor from working, need to attach refrigerant gages to find the problem and know the refrigerant level
Nov 19, 2014 | Whirlpool Freezers
Tip
MOVING YOUR REFRIGERATOR SAFELY!
One of the most common mistakes made while moving a refrigerator
is shaking the compressor, thereby ruining it.
The motor inside the compressor is usually sitting on springs
to allow it flexibility when it runs and to cut down on the vibration.
Especially in older units. The motor inside is wrapped in coils of insulated copper wires. When the compressor is moved it causes the motor to
bang against the inside of compressor, Causing the insulation to break
off and short out.
Just move the Ref or Freezer very slowly and carefully.
Over grass bumps is the worst. It takes a lot longer to move it but it is worth it.
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
imufo2
Leo Ponder
on Jul 27, 2011 | Refrigerators
I have a Kenmore Cold Spot Side By Side Refrigerator/Freezer 106.52572202. The Refrigerator/Freezer was working fine until we moved it to the garage. We can hear the compressor working, but now the...
G'day - look to see if the unit has a cooling fan on the condenser - sometimes when you move a cabinet the hand truck can push up under the cabinet and jam the fan blade - or the tubing under the cabinet has been damaged
Sep 25, 2013 | Kenmore Refrigerators
I have a Crosley refrigerator that is about a year old. We decided to replace it because it wasn't big enough. We moved it to our garage and since we've moved it, it doesn't seem to be chilling the...
If the garage is unheated and the garage temperature is below 50 deg F this is the reason that the freezer is not able to freeze. A refrigerator is designed to work in a heated space. The thermostat is in the refrigerator compartment while the cold evap coils are in the freezer compartment. The fridge thermostat is typically set to around 40 deg F. When the fridge is in a colder environment, the compressor does not need to work that hard to get the refrigerator to temperature. But the freezer on the other hand, will be above freezing.
To fix this, there are garage refrigerator heater kits available, for just this situation. They are placed in the refridgerator compartment to heat the thermostat. This causes the compressor to run longer, and thus maintain the freezer temperature better. You could get one of these heaters or you could put an light bulb in the refrigerator to do the same thing as the heater. Remember to use a regular light bulb, and not a cfl or led light bulb, they won't generate enough heat. Also remove the light bulb or heater in the warm months unless you want a higher energy bill. Hope this helps you.
Dec 09, 2010 | Crosley CFFH10W Top Freezer Refrigerator
My two year old refrigerator is now at 60F although the freezer is working fine. What could the problem be?
There is a fan the moves air over the coils that remove the heat from the refrigerator. That air has to be distributed between the freezer and the fresh foods section. To accomplish that, a fresh foods temp dial is located inside that section and lets in either more air or less. Make sure that it is set correctly. Make sure nothing blocks the opening that the air is expelled from. That air flow is important to that sections temperature maintenance.
Jul 05, 2009 | Amana ABB1927DE Bottom Freezer...
Only freezer works
May 30, 2009 | GE J Series 20.6 cu. ft. Top Freezer...
Freezer will not work due to out side teperature being low
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Jan 06, 2009 | Hoover HCA351K Bottom Freezer Refrigerator
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer not working
is there frost building up in the freezer?mike
Nov 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore side by side not cold
the relay overload on the compressor is bad. very common problem. replace relay overload and it will work again. unplug from wall until you replace it.
Nov 26, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Refrigerators Logo
234 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
