Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Washable filter is getting clogged with dog hair
The filter inside our DC07 is getting clogged with dog hair that should be in the canister.  We have washed the filter and had the internal filter cleaned by a perfessional.  We still continue to have this problem any suggestions?
    Problem Solver:
  • 12 Answers
I have a Dyson Animal Absolute and a rescue white american eskimo dog and two tabby cats.
We found white hair on top of the washable filter and called Dyson to fix it. There shouldn't be anything on that filter.
The Dyson rep said:
Check the black rubber seal that surrounds the "cyclone" holes as it may need to be pushed down because it isn't sealing properly.
To do this remove the cannister and dump out the stuff in there. Do it outside so the fluff doesn't circulate in the house.
Turn the entire filter part upside down so you can see inside.
Check the seal that is at the bottom of the entire filter part and look at the two half moon "nozzles" that **** up the dirt.. now make sure the black rubber band that surrounds those two nozzles is either up or down... do this then vacuum a bit.. check the washable filter to see if it is clean...make sure the rubber seal actually is sealing.. it should just set into place once you have it done properly.
Now if this doesn't fix it, call Dyson, the number is printed on the front of the machine.. and give them your serial number which is located behind the removable cannister. The machine has a 5 year warranty.
Posted on Aug 22, 2009
    Problem Solver:
  • 7 Answers
OUCH! I have a long-hair dog and have NEVER had any hair make it to the filter. It shouldn't make it that far...ever. Call Dyson, get the unit replaced.
Posted on Nov 07, 2007
  • 372 Answers
Hi.
This is very comon most filters do coontain hair & pieces of fluff.
This is due to the weight of the object the heavier items fall to the bottom of the wastebin very light bits can go through the vortex & are collected at the first filter this being the washable filter.
http://dysonmanuals.inc.io/
Posted on Oct 20, 2007
SOURCE:
Why is cat hair accumulating on the washable filter?
Hi there, it's Jack at Dyson.
If more hair and debris than usual seems to be getting through to the washable pre-filter, this is something I'm confident our experts can help you resolve. When you have your vacuum to hand, please give us a call on 1-866-693-9766 (US) or 1-877-397-6622 (CA). We'll look forward to speaking with you.
Aug 06, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
I just ordered/received the filter apparatus that attaches to the clear plastic canister, BUT I can't seem to remove it.
The filters on a Dyson DC07 dont go inside the clear bin. There are 2 filters in this machine the first which is your washable filter is on the lower right side of the vacuum, if your facing the front of the vacuum. to remove this filter you push on the purple fiter catch button and lift up on that filter area then your filter will be in there. the only other filter is your permanate Hepa filter. which sits under neath the clear bin assy but that should almost never be removed. if you do need to the are 3 spots on the gray plastic lid. you take a flat head screw driver and gently slide it in the slots starting with the sides and then moving to the one in the middle in the front and then you just get under the lip and pop it up. and then you can access that filter. but again that is a permanate filter. it should not have to be replaced. and it can never be washed.
Sep 19, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
How many filters does a dyson dc07 have
Hi there, the DC07 has 2 filters. A pre motor washable filter and a post motor filter which will be either a simple pad (like thick cloth) or a Hepa filter (about and inch thick with a plastic housing). The post motor filter should not be washed but the pre motor filter can. As a technician I would recommend replacing every couple of years for best running of your vacuum. The post motor filter is under the clear bin, you can lever the cover off with a small flat blade screwdriver. The washable filter is to the right of the post motor filter inside a removable housing.
Feb 08, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum works but doesn't pickup dirt
there is a clog. check the hose, and the entry to the canister, check the holes inside the canister and check / clean your filter. also remove any threads/ animal hair from the brush so i can freely grab the carpet :)
Mar 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction problem? The carpet fiber and pet hair
You've probably got a lesser blockage further down the pipework, which is reducing the airflow. Check everywhere possible for blockages, and also make sure the washable filter is clean and dry.
Feb 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
More hair in the washable filter area than in the canister?
Mine was doing the same thing. Dyson sent me a whole new "guts" part for the inside of the clear canister (the cyclone, and the rubber ring on the bottom) The rubber ring was not sealing correctly and it has apparently been a problem, so they now have a redesigned one they will send you for free.
Jun 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Clogged filter
I found that the rubber seal on the bottom of my cyclone is not properly seated to the bottom of canister, I guessed when I removed the clear canister bin completely from cyclone unit for cleaning, I put the cyclone down on the floor and rubber seal accidentally move upward just a little. this creates a small gap on the bottom when I reassembled it, (since seal is up from it original position a little). I pulled rubber seal down to its original position, you will notice that there should not be a gap on the bottom at all, this way you do not have to clean or should not have to clean the filter but once a month or even less.
Oct 31, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Washable filter clogging
They have bad seals that allow to much dirt to get through, order new cyclone assy $80.00 it will be fixed on model dc17 very big problem
Oct 12, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
353 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
