Question about LG WM-2277HW Front Load Washer
The washing machine does nothing once the LE code beeps several times
I started a load in my LG it added water but then beeped very fast with a LE code and went to pause
  • 1,543 Answers
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on May 24, 2009
Machine turns on and just beeps
Replace the bad thermistor. Costs about $6. Not that hard to do. Check out repair videos at repairclinic.com. Or appliancepartspros.com
Oct 08, 2017 | LG WM-2277HW Front Load Washer
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Not running giving a beeping noise and a LE sign
if that unit is a direct drive then le code is motor senor or motor fault. change sensor first.when i found this problem at customers machine 90 to 98% it was sensor. please reply 4 more help
Apr 09, 2010 | LG WM1814CW Front Load Washer
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
Le error code
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Try the above..........
Jan 03, 2008 | LG WM-3677HW Front Load Washer / Dryer
LE Code on control panel
Dec 31, 2007 | Washing Machines
All buttons cause machine to beep
Trying unplugging for 20 minutes maybe you can reset it.
Aug 28, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
LG WM-2277HW Front Load Washer Logo
293 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
