Question about Sony DVDirect VRD-MC3 DVD Recorder
Disk will not format
After putting a brand new DVD+R disk.  I get an error stating the disk was unable to be formatted.  How do I fix this?  The disk has never been used.
  • 1 more comment
  • slayerr Feb 05, 2008
    I have the same problem. I have used up close to 25 disks and I keep on getting this message. I tried the sony website, but \i was unable to locate the troubleshhot area.
  • archibaldb Dec 03, 2008
    I could not get the drive to finalize a dics either. it ran on finalizing for more than an hour! Still did not finalize
  • sersim64 Jul 22, 2012
    Hello I have the same problem! Did you find any solution?
My unit will format single layer DVD but not double layer. Anybody have a solution ?
Posted on Jul 06, 2008
Can't make dvd's from my recordings
The recorder supports these formats
DVD-RW · DVD-R · DVD+R · DVD+RW
There shouldn't be a problem with the speed, maybe a compatibility issue with brands.
Also it might be your lens is dirty have you tryed a cd/dvd lens cleaner disk? dry/wet?
May 17, 2008 | Lite On LVW-5045 DVD Recorder
When I put a DVD+RW disk in trys to format the disk then says the disk is protected. If I open and close the door it trys to format the disk again
It may be the brand of disc you are using. Have you tried any other brands? Have you tried DVD-RW? Might make a difference. I'm using DVD-RW and most of them work flawlesly.
Dec 09, 2010 | Sony RDR-GX355
Unable to format the mirco sd card when using it in my computer
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format memory caard
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 17, 2010 | SanDisk 2GB microSD Memory Card
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
Card can not be formatted
There is a write protect switch on the side of the card. That may be the reason why the comp is unable to use it.
Jun 05, 2009 | SanDisk 4GB Secure Digital High Capacity...
Format Error Sony DCR-DVD108 C:1302
Hi Lisa,
What you have there is a bad disk. Sometimes that happens. Disks are made in mass and sometimes the company can make entire batches that are "bad". I recommend that you buy a known brand like memorex, although sometimes, they can mess up too. Just try another disk. Thanks for coming to FixYa, and feel free to rate my solution. Thanks again.
Rob
Feb 06, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony DVD/VCR combo recorder
possible chance the disk has not been formatted ..another chance the disk is damaged .....try with another new disk .......
Feb 05, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Once finalising is complete, put the disk into the PC.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Open Questions:
See all Sony DVDirect VRD-MC3 DVD Recorder Questions
Sony DVDirect  VRD-MC3 DVD Recorder Logo
341 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
