Question about AOC CT720G 17" CRT Monitor
Moniter colour gone pink
Now i`ve got a toshiba monitor 22'' and i changed my cable over from my 37 ince Regza LCD tv it was working fine when i plugged my other cables back from the 22'' screen the colour has a pink tinge .. and not only that i put it back on my LCD tv and its still pink i tried the cables even bought new ones but with no avail i`ve even tried the colour settings and fiddled with the cables No difference still this pinkish tinge.... Any Hellppp????
  • 34 Answers
Cables do periodically go bad. But If I were you I'd be more worried about a bent/broken pins on the end of the cable. Take a flashlight and shine it on the pins on both end of the cable to see if they have any bent/ broken pins. If you do see a broken pin you will want to check the connectors on both monitors to make sure you don't have a broken connector pin stuck in them. Also  If the broken pins are stuck in the monitors I'd reccomend going to an electronics repair shop to have them fix it for a low price, But this is a worst case scenario. I'd bet its just a bad cable, or the cable just went bad.
If you don't see any signs of broken pins, then I'd reccomend getting a new cable and a higher quality/heavier duty one.
If its a "VGA"(analog) cable with blue connectors, I would reccomend upgrading to a HDMI or DV(Digital format) I cable if possible. And if thats not doable and you must use VGA for some reason I'd reccomend getting a heavier duty cable from an online shopping site like newegg.com. I personally just got a Rosewill VGA cable and it works perfectly for me. Just make sure you get the correct female-female connector types and also make sure its the appropriate distance. And remember if your getting a VGA(analog cable) the shorter or less cable you need the better, since analog cables degrade over larger distances.
Posted on May 24, 2009
WHY I HAVE GOT HARITONZAL LINES ON TOP OF SCREEN ON TOSHIBA LCD 37RV635D
sounds like the same problem as with most screens. it could well be the screen as gone
Apr 26, 2014 | Toshiba 37RV635DB Regza 37-inch Widescreen...
47regza has a pink screen says no video signal
Try changing the input device to something you are sure, works such as a DVD player. Look for loose contacts of jacks, sockets and cables.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Toshiba REGZA 52RV530U LCD TV
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
My flat screen toshiba has gone black and white. The picture is lovely except no colour. I have sound
If you are connected to an HD cable box or satellite box via component cables, make sure they are firmly seated at each end.
Sep 02, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a Toshiba REGZA LCD Model 42XV600A and am having problems with the picture. The picture was fine but now the colours are all out of whack. I have checked the connections and aerial reception and...
Go in ur tv menu go "Picture"go down to reset.Press it,will go back to Factory setting.The colors should be back to factory setting.Not,than ur tv Main Tuner signal board is the cause must change to fix.
Apr 04, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My sound as gone on my toshiba regza tv
Does the sound icon move up like it should on the screen when you increase the volume?
Dec 09, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba regza lcd hd ready, black gone green?
you haven't got any speakers close to your tv have you? it sounds like magnetic inteference??
Jul 05, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Which lead do i need
get a pc cable from your local computer shop serial port to serial port and bobs your uncle
Mar 23, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Pinkish Color on Monitor
Most likely it is your VGA cable gone bad. I remember doing a warranty call for HP once, I was the third tech to go out and replace a motherboard. When I got there, I found out that the cable was bad and it was giving everything a blue tint. I would certainly recommend replacing the VGA cable. I bet if you wiggled the VGA (monitor) cable on the back of your computer, it will come and go.
Jun 09, 2007 | Samsung SyncMaster 913V 19" Flat Panel LCD...
AOC CT720G 17" CRT Monitor Logo
411 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
