Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi rear projection tv won't turn on, just green light on front flashes quickly. Tried resetting with pencil point per manual and no luck
  • 28 Answers
First remedy if u can read schematic circuit diagram u hav to bought it indicating its model/brand at an electronics store, look up at power supply section at the diagram and read voltages at each test point if it is correct by using voltmeter.
Second remedy is to check the output voltage at your convenience outlet where you just plugged-in your TV set maybe the voltage output is lower than required 110Vac(European countries), 220Vac(Asian countries). Then try to plug it in differrent locations in u'r home. ok..
Posted on May 24, 2009
Where is the reset button on a mitsubishi dlp 73' tv?
  • Open the front panel by pushing on it. Pressing on the panel releases the lock and allows the front panel to pop open slightly. Pull the corner gently to open the panel completely.
  • 2
    Use a pointed object, such as the sharpened end of a pencil or the tip of a paper clip, to push the "System Reset" button.
  • 3
    Wait about one minute, or until the green LED light on the front panel display stops flashing.
  • 4
    Turn your television back on once the green LED light turns off.
    this is procedure for most mitsubishi dlp.
Oct 15, 2013 | Televison & Video
What do you do to get the error codes?
try to reset the
  • 1
  • 2
  • 3
  • 4
God bless you
Jul 27, 2013 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Green light won't stop flashing. Unable to turn off/on or reset.
Aug 21, 2009 | Mitsubishi WS-48515 48" Rear Projection...
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
317 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
