Question about Eiki LC XNB3 Multimedia Projector
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
My EIKI LC-XNB3 Projector does not recognize any Vdeo Inputs, but works great when hooked up to a laptop. I have tried all three connections to my DVD/VHS player ("S" Video, Y-Pb/Cb-Pr/Cr, Composite Yellow) and I have tried to manually change the input selections through the menu. Is a circuit blown? Is there a blown fuse (and if yes, where?)
I am game to try and fix it myself, if possible.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
There might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
Posted on Apr 17, 2014
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: LC-XNB3 won't turn on
check lamp compartment cover and confirm that it firmly closed-check power cord and power in outlet(electricity)
Posted on Jul 08, 2008
projdoc
  • 2237 Answers
SOURCE: Eiki LCSB Projector: no input
make sure the resolution matches the input.
Posted on Aug 19, 2009
projdoc
  • 2237 Answers
SOURCE: in few minutes after turn on the projector (Eiki Lc-xnb4m) ..
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Posted on Nov 18, 2009
projdoc
  • 2237 Answers
SOURCE: new projector. which cords do I need?
laptop, vga. dvd, composite or s-video, and audio. gaming console, composite or hdmi, if you have it.
I have an eiki lc xg400 at my disposal. I have a toshibi vcr/dvd player. How do I hookup the vcr to the projector and is the hook up different for the dvd? Thank you De
this depends on the signal type coming from your sources
best is using component signal ( Y-Pr-Pb) , by using the right cables and right settings for video inputs in the projector menus.In basic this should be possible.
Mar 30, 2011 | Eiki Office Equipment & Supplies
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
New projector. which cords do I need?
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
I do not know how to use Eiki LC-300
The operation manual is at this addres (http://www.eiki.com/docs/owners-manuals/lc-300_owner-manual_2000-06-05_en_na.pdf?sfvrsn=14). It is a PDF & very easy to download. If you need any other help, write back.
Oct 14, 2008 | Eiki Projector lamp Projector Lamp for...
Jul 04, 2008 | Eiki LC XNB3 Multimedia Projector
Black and white projection
Hi there
First try another cable from the PC to the Projector.
The VGA / RGB Cable used from your PC to the Projector has a couple of very thin copper wires on the inside and they easily get damaged.
If this doesn't help then you should try another PC.
If that works then you'll know that it is the PC's card that is faulty.
If it doesn't work you'll have to get the Mainboard repaired or replaced , because the inputs on the Projector lies within the Mainboard.
Must warn you that a Mainboard replacement is a bit on the expensive side.
Mar 26, 2008 | Eiki LC-SB20 Projector Multimedia...
Eiki LC-xnb4m computer connection issue
I actually fixed it myself--I found another site that said for Dell systems, you need to hold down the Fn button (bottom left) and push F8 and then it recognizes the projector. Solved the problem immediately!
Jan 27, 2008 | Office Equipment & Supplies
Problems changing lamp
Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
May 19, 2007 | Eiki LC XNB3 Multimedia Projector
Eiki LC XNB3 Multimedia Projector Logo
254 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
