I have a rca 54" model (p52753at) it quit working awhile back and i replace the hv splitter and the focus control (it was cracked severely) tried to turn it on and all i get is a series of clicks near the plug ?????? any ideas?
  • Anonymous May 24, 2009
    no, not sure where to check. thought about taking it to a repair shop but i'm doing this as a project so learning as i go. where would i look?
  • bunnyhumpers May 24, 2009
    would the flyback 20054,2g25018-a3a be the problem? 200200450, 2G25018-A3A450, 2jG25018-A3A
  • 8,617 Answers
Have you checked for a shorted or open HOT ?
Posted on May 24, 2009
Rca D61W20 52 in power supply
If the deflection power board was changed with a known good one . then the HV splitter block would be suspect then followed by a bad CRT next. I would try removing one CRT drive board at a time by letting it hang free wires attached then trying to power up the set if it doesnt power up then try one of the other crt drive boards after reattaching the one you previously unhooked. If the set powers up if any certain CRT board is removed you will know the problem is that CRT. If it doesnt power up then its most likely the HV splitter. You can get replacement CRTs, boards and HV splitters that have warranties from www.tvrepairworld.com
Jan 22, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
When Turned on screen turns bright the TV turns off a few seconds later
there are some transistors on the board that reads good when tested but under load they fail replace all of the transistors and diodes that will take care of your problem.good luck.
Jun 06, 2007 | RCA HD52W140 52" Rear Projection...
The tv was working and made a hiss and pop and quit, I replaced the flyback and now it just ticks
When you replace a flyback on an RCA Model, Always replace the Horizontal Output tranistor with it. These models are notorious for for bad solder connections in and around the HV area. Also check around the High Voltage Area for bad HV Scaning Capacitors. These are usually square shaped , for cracking,arching,and swelling. Replace if found to be defective. One more thing check the neck of the picture tubes for cracks or arching inside a tube when trying to turn the set on. Sometimes a bad scanning cap will go defective and drive the high voltage so high it cracks the Green CRT.
Nov 15, 2009 | RCA P52960 52" Rear Projection Television
After replacing hv splitter and focus block and about four hours of adjusting the convergence board in the front I finally got a great picture, but now i notice when you have a title like on my dtv...
Is this set a RCA ? You may want to double check the seating of the Anode Lead from the HV Transformer to the HV Slitter, If pulled out
a little arching will occur with-in the Bock and cause premature failure if not corrected. Also make sure that all ground connctions are made from the CRTS to the HV Block if there are any.
Hope this Helps,
Skyassoc
Jun 20, 2009 | Televison & Video
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Projection tv not working
I guess loud sizzling was from High Voltage Splitter in your TV. HV seems cracked and leaking high voltage.
You can observe and confirm it by removing back cover and power up TV from distance and check at rear of TV. Please take care and there should be little dark to observe arc from HV splitter.
If this is the case, HV splitter available in Part Store.
Dec 16, 2008 | Televison & Video
Tv repair
HV splitter and flyback are common failure items. Remove the HV lead from the HV splitter that comes from the flyback, Place that into a dry glass jar secured so it doesnt come out. Then try powering up the set if the set powers up without shutting down the splitter is bad.
Mar 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
Feb 09, 2008 | RCA HD52W140 52" Rear Projection...
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
No Power and beeping noise in circuitry
had a 51" rca rear projection donated to myself. While off and power button pressed there was a clicking noise from the front of the unit. Rear cover was removed and it could be observed that the hv splitter had a crack in the casing and the power was arcing out of the splitter. I purchased a $72 dollar hv splitter, i read that the $20-$30 dollar one would break within a year, and the unit powered up no problems.
Nov 20, 2005 | RCA P46920BL 46" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
