Question about Flat Panel Televisions
Black rectangle on screen on some stations
I get a black triangle on the screen on some stations. It is not all the time. I am hooked to cable not thru a box. The cable company tells me it is a setting on the tv. Help. I can not figure it out.
Re: black rectangle on screen on some stations - Flat Panel Televisions
Turn closed caption option off on t.v.
Posted on Feb 15, 2008
It has something to do with the closed captioning.  Try gonig to the cc option and see if you can turn it off.
Posted on Oct 22, 2007
0 characters
3 Points
I get a black rectangle in the middle of the screen. I can click any button (mute, view mode, cc) and the black rectangle will go away and whole picture will appear, for a couple of seconds and then the...
I do know that on Zenith CRT televisions of the 1990's this will happen and all I did to fix it is to go to the menu and turn the text feature off. This may be true with your Sharp as well.
May 21, 2011 | Sharp Aquos LC-32D40U Television
A black rectangle appears constantly with numbers and letters typing in it
you need to go in the menu and remove the cc1
or cc2-3-4 these are screens designed for showing
tv station programming and other infos but they never used it
Sep 28, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Small black rectangle in upper left corner of toshiba 52hm85 dlp
Sounds like it is closed captioning coming up. I would go in and verify both your TV's and the Cable/Satellites closed captioning is off.
Mar 06, 2010 | Flat Panel Televisions
TV is about 1 year old. Started yesterday having a black rectangle in the middle of the screen. Can press any button and it goes away but come's back in just a few seconds. Tv is a Element ELCHS321
most times a black rectangle pops up when closed captioning is on. sometimes there will be gibberish in it sometimes not. See if you have button on remote labeled "CC" . Also if you have a cable or sat box make sure closed captioning is switched off there too.
Jan 21, 2010 | Flat Panel Televisions
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Flat Panel Televisions
I have a black rectangle in the upper left side of my screen on all stations but not on info or guide. please help
I had the same problem and it turned out to be my Bell Express Vu. I pressed and held the main button on the box to reset it and have not had any problems with it since.
Nov 27, 2009 | LG 42LC2D 42 in. LCD HDTV
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Sharp Aquos LC-46D64U Large black rectangle in lower half of screen
It sounds like the closed caption text mode has been turned on. Use you CC button on the remote and make sure the closed caption mode is in the off position.
Jan 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Black rectangle
If the black rectangle is in the middle'please check to see that the closed caption is not activated.If not please provide the location of the rectangle.
Jan 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Flat Panel Televisions Logo
383 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
