Question about Logitech X-530 Computer Speakers
3 of 5 speakers not working.
I have everything hooked up right,  the front 2 speakers and the woofer work fine, but no sound out of the others.  i know this problem has already been solved but I dont think its the same.  I have a laptop with an external soundcard that should be able to support the surround sound.  its a creative sound blaster.  when i take a back speaker and plug it into one of the spots for a front speaker i get music, so the speakers and functional.
  • 13 more comments
  • harry75411 Dec 13, 2007
    The front 2 speakers and the woofer work fine, but no sound out of the others. I have a PC with a sound blaster sound card that should be able to support the surround sound. its a creative sound blaster. when i take a back speaker and plug it into one of the spots for a front speaker i get music, so the speakers are functional
  • Anonymous Dec 27, 2007
    i just bought a new 5.1 sound card and installed it and then hooked up my x-350 and i had the same problem. i tried putting the rear speakers in the front speaker port and it worked but that left me without front speakers
  • Anonymous Mar 06, 2008
    rear speakers have hardly any sound output. when i swap them with the front speaker its the same problem just reversed.
  • Anonymous Mar 29, 2008
    my 2 front speakers work but the back 3 dont work how do i fix this ??? its on a lap top thats not working on. not a normal computer.
  • kenmlion Apr 03, 2008
    I've hooked up the X-530 system correctly, and have adjusted the audio system to handle 5.1 surround sound with 5 speakers and a woofer, and only 2 speakers and the woofer work. I can either get the front or back working , but not both. The system is not adjusted to stereo. Any ideas to get the five speakers working?
  • Gainesy Apr 13, 2008
    I am trying to play my ipod through the speakers. What do I need to buy to get all the speakers working. Again only 2 speakers work!!!
    Thanks
  • lakusta12 May 30, 2008
    I have logitech x-530 surround sound and i have used it before and it all worked fine...i recently re formatted and now only 2 out of my 5 speakers are working. I have installed numurous drivers and still nothing....I tried installing the realtek audio driver because i use a asrock k8 combo-z motherboard with onboard sound and i got an error message halfway through installation and it quit the install PLEASE HELP!
  • Anonymous Jun 14, 2008
    my 3 speakers doesn't work
  • susu sammaka Jun 19, 2008
    hi there,i set up my speakers and only 2 of the speakers are working and i have put all the colours in the right places exactly what the insructions say .thanks
  • Anonymous Jun 24, 2008
    3 of the 5 speakers are not working
  • jidjwaijw Jun 24, 2008
  • ducatiboy Sep 13, 2008
    all my speakers work,if i plug it in the center jack.but if i plug all of them in the jacks they are suppose to be in no sound from the speakers only the front.what can i do to solve the problem...thanks
  • Anonymous Sep 25, 2008
    nly 3 speakers working,tried changin it to 5.1 setting but nothing
  • Anonymous Oct 04, 2008
    plse guys help me quick i need sound from both speakers no 1 when i plu it in to the front the back one dont work
  • Anonymous May 09, 2009
    I also own the 5.1 X-350 and I tried everything i knew. Both rear speakers and the center speaker do not work when I hook them up to my computer or tv(for xbox360). I really don't know what to do now. Thanks in advance
Normal stereo sound its not 5.1 if your hearing music its stereo and not in 5.1 channels, you need to activate the Creative Sound EAX sorround mix, check on the EAX console, there you can simulate 5.1 or clone the 2.1 channels to the rear speakers, i like more the simulation works better... simply sends some freqz to the rear speakers
Posted on Sep 29, 2008
To make the logitech x-530 work with all speakers you must have at least a 6 channel sound card, will work with 7 and 8 channel too
Posted on Jun 08, 2008
Go into your computer audio system and make sure you are on you are not set on stereo
Posted on Dec 19, 2007
SOURCE:
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Front right speaker is not working
This may sound obvious, but have you plugged in all the plugs?a 4-channel sound system has two plugs that plug into the sound card.One is for the front speakers and part of the subwoofer, the other is the rear speakers and the other part of the subwoofer. AC97 audio normally supports only 2-channel.s your sound on-board?how many sockets does it have.A common AC97 normally has a green plug (for 2.1 speakers), a blue one for line in and a red one for a mic.A four-channel one will have a black socket for the other two speakers.and 5.1 has a yellow socket for the 5th speaker and woofer.
If your AC97 audio does not have the black socket, then you will need to buy a special card, like the Sound blaster 4.1 Digital (around £20-30).Or, if you want a 5.1 card, the Creative Audigy is considered the best, as the Audigy 2 is still expensive, and there are cheaper cards for 4.1.
Hopefully this should sort out the problem.I also have Creative Inspire M4500 4.1 speakers, and they have 2 plugs.
Jul 07, 2009 | Creative Labs Inspire 4400 Computer...
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
No sound out of woofer
Hello sparkie102
Happy Holidays
you have to check if all the cables are well connected, and in the right inputs. 2) check your software for sound that is enable, fine.
turn up the sub volume , if got it independent.
other that this, is a failure sub. if got warranty, use it! or RMS your sub.
Dec 26, 2007 | Logitech Z-2300 Computer Speakers
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Logitech X-530 Computer Speakers Logo
1,674 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
