Question about Refrigerators
Freezer not working
Hotpoint refrigerator/freezer side by side;back coil keeps freezing over and temperature drops in refrigerator and freezer
    President:
  • 1,136 Answers
Hi, are you getting ice or frost build up.
The most common part that goes bad on these are the defrost heaters. THe defrost heater is below the evaporator coil and usually has a blue and pink wire to it. Test the heater for continuity. If it tests open, replace the heater. If it tests closed, check continuity on the bi-metal stat located on top the evaporator fast to the coil. The bi-metal stat has to be tested cold. Again, if it tests open, replace it.
If both of these test ok. you wil need to replace the defrost control.
Please let me know if this has helped you or if I can assist you further.
Thanks
Vic
Posted on May 24, 2009
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
Refrigerator/freezer quits working, I unplug it, plug it back in, and it works great for a week or so. What do I need to replace to fix this problem?
the freezer coil is probably freezing up. if so you have a bad defrost thermostat, heater, timer or board or combination of them.
Mar 01, 2012 | Hotpoint HSS25GFP Side by Side...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
The freezer on my hotpoint side by side is barely cooling and is above freezing temperature. The refridgerator side is just fine. What could be wrong with the freezer side?
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 14, 2010 | Hotpoint Refrigerators
Water line keeps freezing.....
Probably the easiest possible solution might be to raise the freezer temperature a bit. If the freezer does not have a built-in thermometer that shows the temperature, get one and sit it inside the freezer. Wal-Mart should have these.
The temperature in a freezer should be around zero, plus or minus a few degrees. If the freezer shows a temperature significantly less than zero, you could certainly adjust the temperature control to raise the temperature a bit without causing any problem.
The water line runs outside the freezer for most of its run. However, it must come inside to reach the water dispenser. This short distance is where it would be susceptible to freezing.
Oct 20, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Will my mothers new fridge freezer work out in the garage
This is from the hotpoint web site.
If the room temperature drops below 14°C for an
extended period of time, the ideal temperature will not
be reached in the freezer compartment and food
preservation will be reduced.
You can read the manual here if it will help you.
http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19504293107_UK.pdf
Good Luck
Jan 11, 2009 | Hotpoint Refrigerators
MAYTAG MSD2354ARW
How great is the freezer temperature? Look for frost on the freezer back wall. If there is frost there you have a defrost system problem.
the refrigerator is cooled by air it receives from the freezer. When the freezer coil freezes up the air circulation stops.
May 30, 2008 | Hotpoint HSS25GDMWW Side by Side...
Hotpoint hss25gp Not keeping cold or freezing
Check and clean the condenser coils where heat is transfered to the room air. If they are plugged with dust it will cause your problem. Check the back wall of the freezer for snow. If snow is on the back wall you have a defrost system problem.
Mar 09, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
