Question about LG 42LC2D 42 in. LCD HDTV
Dvd i don't know what cables to put in what hole for th dvd player
  • 4,889 Answers
Http://www.audioholics.com/tweaks/connecting-your-system/dvd-player-setup
Go thrugh the above link you will get all the info you need and please rate this thread..
Posted on Oct 20, 2007
What do I need to do if the Dvd player says no disc and will not open
First of all check that ALL the cables are plugged into the correct place, look for a small hole just under the DVD player. Very Small hole. Find a small round metal object that will fit into the hole & gently apply pressure & it should then open the DVD player. The only suggestion I can advise is try putting a cleaning DVD into the DVD & see if you can make it play this may be all it needs. Best Wishes. Malcolm.
Sep 28, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
I need to know how to hook up a d DVD/VCR to it.
Ur tv have a RCA INPUT holes like Y,R,W INPUT holes from the Front or the Back of the tv wright?Yes.U must buy or have it already a RCA components cable Y,R,W wires.Connected the RCA components cable Y,R,W wires to the DVD player Y,R,W OUTPUT holes and the other end of the RCA components cable wires Y,R,W connected to the tv Y,R,W INPUT holes.Now the tv and DVD player is on ok.Now u playing the DVD player contents Disc and push the INPUT modes on the tv like VIDEO 1 or 2 by the tv remote or manual button on the tv.Now u should have video picture of the DVD Disc contents playing.
Aug 15, 2011 | Philips Magnavox MT2501C 25" TV
How to install a video machine if I don't have the tv remote?
I'm assuming by "video machine" you mean some kind of DVD player or Blu-ray player or something of the like. I will explain how to install a DVD player. There are two major cables: one sends the video to the TV and the other sends power to the DVD player. The power cord plugs into the wall with the other end attached to the DVD player. The video cable plugs into the TV. If you have an HD television, the video cable will have a male HDMI piece that plugs into the TV while the other end of the cable plugs into the DVD player. If you don't have an HDTV, then you will use an RCA cable which has three prongs: Yellow, White, and Red. These three colored male prongs plugs into the corresponding color coded holes in the TV. The other end goes into the DVD player. When you have everything plugged in correctly and the DVD player is on, all you have to do now is change the TV input. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc. Keep going until you are on the correct input to see the DVD player menu. Good luck!
Jul 01, 2011 | Philips 42PFL5332D 42 in. LCD Television
How do I put it together?
Plug the fat cables into the monitors on the bottom, and then to the player in the D shaped holes. Plug the 12V (car) adapter into your car's power outlet and then to the player in the small hole that may be marked AC/DC in. There's only one hole that will work - can't mess it up.
Aug 06, 2010 | kawasaki PVS1965 Portable DVD Player
When I hook the HDMI cable to the tv and put the dvd player on the setting for 1080p I get no picture but when I put it on 480p it works fine. What do I need to do to make the dvd player to play the 1080p?
you can only upscale through a good amp.set the dvd player to auto.how old is the tv?are you playing a new release?is the HDMI cable compatible with 1080 1.3b?
Jul 11, 2010 | JVC TH-G30 Theater System
I can't find the booklet on this DVDplayer and I don't know how to hook it to the TV or what channel the TV has to be on. I put the red, white & yellow connections in the Output/Video on the back of...
The the RCA cable YELLOW,RED,WHITE should hook in those holes said "OUT" on the DVD player.The tv should get the other end RCA cable YELLOW,RED,WHITE said "IN" hook in those holes in the tv.Now ur tv should play dvd disc,on the tv mode or av modes like 1,2,3 modes.
Jun 09, 2010 | Pioneer DV-250
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
Help
What video out put you connected between JVC player and TV ?
Look at back of your JVC player for Video out (yellow color) pin, hook RCA cable there and plug it to Input-1 or 2 in TV.
Now select AV 1 or 2 (what ever you hooked) in TV by remote and hopefully picture will in TV.
need further help, let me know model number of your TV.
Oct 11, 2008 | JVC TH-M45 System
Dell inspiron 2200
at the front panel of the dvd drive where u normally press the eject button look carefully u will find a very small hole some where in around the eject button. now look for a broom stick or any tiny but straight object that can go in through the hole. put the broom stick into the hole gradually not with force. the dvd player will eject if it doesnt eject then i dont know.
to replace a new dvd player u just unplug the formal one from yr system and insert the new one thats all. make sure no screws r holding the dvd player b4 u do so.
hope this helps
do come back n tell us if don
thank u
May 26, 2008 | Dell Inspiron 2200 Notebook
LG 42LC2D 42 in. LCD HDTV Logo
57 people viewed this question
