Question about Water Heaters
Age of MW Water Heater
Would you be able to tell me what the age of my water heater is:
Montgomery Ward SNN 1087A246i91 40 gallon
Model #SRM33685
Deluxe Energy Saver 500
An answer would be appreciated. Thank you!
Kathie
  • 252 Answers
Mfr date 10/87
Posted on May 24, 2009
How to determine the length of a rheem water heater ?
Do you mean size?... height, width, and diameter of a specific model?
Or do you mean the length of warranty coverage. You will need serial number located on label on side of tank.
Or do you mean age of water heater?
Suggest contacting Rheem.com
http://waterheatertimer.org/Water-heater-warranty-by-brand.html
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
Gene
Aug 27, 2014 | Water Heaters
Montgomery Ward
you didn't specify whether it was electric or gas, so i'll assume it's gas. Clean or replace the thermocouple that the pilot light heats. Yes it could be the thermostat as well.
Nov 07, 2013 | Water Heaters
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
Feb 03, 2013 | Water Heaters
Gas hot water heater won't lite
Copy following link for troubleshoot by type of gas control valve, depending on type, model, brand and age of water heater.
Copy following link for testing and replacing thermocouple or thermopile, and general steps for cleaning air intake depending on year, brand, and type, and age of gas water heater.
http://waterheatertimer.org/How-to-replace-thermocouple.html
If you have tankless, then copy following link for possible help
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 21, 2012 | Water Heaters
Need a blanket for Rheem Water Heater model #22VRP75.
You have 75 gallon gas water heater.
I install water heater insulation 3 ways:
1) Easiest: buy ready-made blanket from Lowes and use duct tape
2) Harder: wrap heater in ordinary fiberglass insulation and use tie wire
3) Hardest: Build a box out of blue styrafoam >> leaving room for air intake for gas water heater, and space around vent pipe
Instructions for gas water heater:
Do not cover TP valve.
No insulation is put over gas valve or air intake.
No insulation touches vent pipe.
Remember the gas water heater has to breathe air into the burner, and aftter combustion takes blace, hot gases escape so extra space is left around hot vent pipe to avoid fire.
Find age of Rheem: look at 3rd and 4th digit of serial number, for example 06 was manufactured in 2006.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Rheem Tank Water Heater G75-125, 75 Gallon
My heater is not getting hot i can not tell if their is a pilot light or a reset button i don know what to do with the heater it is very different how can i heat my water heater
Reliance makes gas and electric water heaters.
http://www.reliancewaterheaters.com/
Best way to start is to look at label on side of tank.
Label has serial number, model number, plus it will say if heater is gas or electric.
Reliance water heater age is shown in serial number: first digit is letter, second two digits are numbers: for example numbers 02 would be the year 2002.
If water heater is 8-12 years old, it might be time to consider new tank.
Gas water heater has 3 inch metal flue pipe coming out of top of tank.
Gas pilot is probably off.
Relight pilot light: Most gas water heaters today have instructions on side of tank just above gas valve that say how to relight pilot light. Instructions vary by model.
If you have gas water heater that is older, it might be easier to call a plumber.
Electric water heater has panels on front.
Open top panel and push in red reset button.
If you have electric water heater of any age, you can usually fix it yourself same day:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 03, 2010 | RELIANCE ELECTRIC WATER HEATER
I have an Atwood Direct Ignition Model G6A-4E 6 Water Heater
I am a RV service tech and that is an old unit. Your control board is bad but with the age of that unit I would strongly suggest replacing the whole water heater, you can shove a pile of money at it and still have an old water heater when for 3 to 500 bucks you can have a new one with a 2 year warranty
Mar 03, 2010 | Water Heaters
Water Heaters Logo
169 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
