Question about Toshiba 42H81 42" Rear Projection Television
Push power sounds like it turns on but it doesnt
42" toshiba cz36v51, push power and sounds like it turns on but it doesnt
  • 111 Answers
Discharge the power from the set before you do anything. HIGH VOLTAGE!!! Look at the power supply. It will be in the area where your power chord is soldered in. Toshiba sets are notorious for the mosfet chips going bad. But your problem almost sounds like some bad capacitors. If the mosfets were bad, you wouldn't have any power to your buttons/LEDs. Replace all of the capacitors within the power supply section. They're cheap.
Posted on May 24, 2009
Toshiba tv power light flashing. Model. Number cz36v51 how can I fix it
What colour is the flash? Is there any picture and sound? Need to provide more data to diagnose the problem.
Feb 09, 2015 | Toshiba Televison & Video
How do I replace the remote sensor on the front of my Toshiba CZ36V51...I have the sensor part....is this done by prying off the front black panel at the power button??
you need to take the back off unplug all cables (mark were they go back) take of the fly back cable (top of tube) by lifting the rubber crimp the strike pins pull of. the take out circuit board and there at the front will be the ir sensor desolder it and replace with new one
good luck
let me know how you go
Dec 29, 2010 | Toshiba CZ36V51 36" TV
Hello! The picture on my toshiba cz36v51 is halved vertically, and has a duplicate picture on either side. Is that fixable? This problem occurs when trying to watch movies, cable, xbox...etc. Fixable or...
Sounds like you have a horizontal timing error causing the mirrored image. It is fixable but would require the main board to be replaced. The part number is 23783078 but appears to be no longer available.
Aug 28, 2010 | Toshiba CZ36V51 36" TV
After power button is turned on the led light flashes, and the only way I can get a picture is to bang on the front of the tv by the power button.
Sounds like you have a "Dry Joint" or bad connection, or even a faulty power switch.. this is a fairly common one... try a switch replacement first? Or look for a bad joint on or around the switch connections.
Jan 30, 2010 | Toshiba CZ36V51 36" TV
Good evening, I have a Toshiba CZ27V51 and recently I disconnected, then reconnected a digital box to it. Since reconnecting, the TV will not power on. It sounds like it is going to, however the power...
sounds like a bad flyback transformer p/n 23236492 .but you would need to know how to solder . and crt safty. no reset that i know of with that symtom.
Sep 28, 2009 | Toshiba CZ36V51 36" TV
42" standard tv
the internal bulbs have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
May 24, 2009 | Toshiba 42H81 42" Rear Projection...
I have a Toshiba cz36v51 that won't come on...
I do not have that make and model. However:
Some remotes have to have a code set that matches the brand of the tv. Your remote should have come with a list of brands and codes.
Alternatively, the instructions for your remote should tell you how to determine which code to use.
Mar 20, 2009 | Toshiba CZ36V51 36" TV
Toshiba power led blinking
check your horonital output transistor could be defective.
Jan 26, 2007 | Toshiba CZ36V51 36" TV
Toshiba 42H81 42" Rear Projection Television Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
