Printers
Problem for Printers
Generic problem for all Printers
Printer stopped working
By postalcurtis on Oct 20, 2007
It was working.  Now it's not.  Everything is connected.  I've tried turning everything on and off and reconnecting everything.  I wonder if I need to reinstall the software but I can't find it or the user manual for troubleshooting.  If you can give me some ideas I am anxious for suggestions.  thanks.
Same Problem
Nov 19, 2008
-   There was a paper jam and then my printer just stopped working. I have pressed the On button and the OK button, but nothing happens. -   Slow Tech
Jun 19, 2008
-   no longer working. will not cut on.-   ellacw
Jun 12, 2008
-   Printer wont feed into printer Epson Stylus D. 78-   Guest
Apr 20, 2008
-   Canon i350. Won't power up after electrical power surge. Think it burned out the internal ac power adapter. It's really not internal at all, but since it's attached to the external frame of the printer, guess it can't be called an external power adapter. Does anyone have a source to replace the adapter (Part # k30209)? Or does anyone have a problematic Canon i350 and would like to part out the adapter?
Thanks
Ted
-   abd5741
Mar 24, 2008
-   Won't respond to turn on - tried other outlets - moved from studio to house - now scan light is on and won't go out-   Guest
Best Solution
posted on Oct 20, 2007
Very Helpful)
Soulvisitor
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 2381 votes
Check printer, is it ready/online ? Do a test via keypad of printer and see if printer is ok.
If printer is ok then check again cable that goes from it to PC
If printer is not working, check for error lights,display,paper,jams.
We need to know Model and Make of printer, what you are using to print, and how it's connected, to help you any further.
Was this helpful?
Yes
No
Solution #2
posted on Jun 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you won`t accept my password on fixya
Solution #3
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the printer dos`nt work all. There were loud noises coming from the printer when I tried to printout photo`s on Epsom photo`s, now it wont print and more help
Solution #4
posted on Jan 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
GenericClass: waiting for Device
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a... (More)
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
After I up-dated window xp service pack 3, I install the Brother 512C fax scanner printer DC, it... (More)
Answer
I cant print from my wireless computer. working fine until a week ago. computer is sending it but... (More)
11 Other Users Have The Same Problem - Continued
Comment by mycr125, posted on Feb 24, 2008
lights
Comment by alessa, posted on Feb 17, 2008
The printer is plugged in and will not turn on.
Comment by emagdnim, posted on Feb 03, 2008
It was working the other day, but now it only turns on for a second. I refilled the ink, both, and i took all the paper out, it just wont turn completely on. When i unplug everything, it turns on, but only for a second.
Comment by lilangels, posted on Dec 12, 2007
The printer worked great then ran out of ink. I replaced the cartridge now it won't work. I've turned everything on and off and tried all the USB ports. There's no paper jam and the ink is full, it just won't print, but the On/Resume light is flashing. Any suggestions?
Comment by nicky_1982, posted on Dec 06, 2007
the MP 390 shows error "CHECK PRINTER"
it was working smoothly untill recently,
there are no electric problems & other options like scan & fax are working
Comment by Guest, posted on Nov 22, 2007
The printer pulled through several sheets of paper then jammed. I removed the paper but since then I have been unable to turn the printer on. The light on the hub does not come on when the USB from the printer is connected to it. I have tried switching off and on but it still is not working.
Describe your Printers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Van Nuys, CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
