Question about Smeg 23 in. SA435X Electric Cooktop
Change the location of a cooktop
We are trying to buy a house but do not like the cooktop located on the kichen island.. I wonder whether it is changable, for example move the cooktop to against the wall..
  • difeil May 24, 2009
    Thanks a lot!
  • 31 Answers
Sure can but need to move the power to the new location. not hard sometimes if you can access from under the floor. need to see if you have a finished ceiling under or if you can get to it easy.
Posted on May 24, 2009
Frigidaire electric cooktop locked
I appreciate your post, friend!
I noticed your question is labeled under Frigidaire cooktop model, FEC30S7E. I have located the Use and Care Guide for your cooktop and I was unable to locate a lock feature. You could perform a reset on your appliance and you can do that by unplugging the power cord or flipping the circuit breaker off for ten minutes.
If that does not correct your issue could you please provide me with your model number? Usually you can locate the serial tag (which lists your model number) inside your burner box or on the outside of the appliance base. With that information I can look further into your model. I look forward to assisting you. -Matt
Oct 09, 2014 | Frigidaire 31 in. FEC30S7E Electric...
Belling GHU573 Gas Cooktop
hello,
If the electricity is needed to ignite that cooktop, you can install power inverter from DC to AC. you can use 24 volt battery and inverted to 110V or 220V or depending on the power input of the cooktop..may this help,
melnavz
Apr 08, 2008 | Belling 27 in. GHU573 Gas Cooktop
Ignitor does not click
there is no "ignitor" as you would find in an oven or dryer. There is a sparkmodule that many times goes bad after 5 to 8 years. It is a plastic box about 4 to 6 " x 2" wide and wil have 3 to 5 wires or 3 to 5 terminal connector points on it. remember to unplug the range top fromwall electric. these units are not difficult to replace; they are not repairable, you have to buy a new one.
Apr 28, 2010 | GE Profile JGP636 Gas Cooktop
Thermador cooktop ignitors won't stop clicking
I have the same range top. I am looking for the switch assembly. Do you know where I can buy this part? Please email me if you do. prboardman@yahoo.com
Dec 30, 2009 | Cooktops
Should I buy a two burner unit if available? Or a new cooktop?
Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
Dec 29, 2009 | Cooktops
Stainless Steel Cooktop - Remove Sealant Spray
try paint thinners , but before you do any thing you need to call the workman to see what brand of glue he has used.or to come out and clean it off for you or to see if thinners will work , it normally does but when i do resturant kichens out any spillages of glue is removed straight away.you will need to use polish cleaner after the thinners to stop any further marks appearing
Feb 17, 2009 | Thermador PC366BS Stainless Steel Gas...
I have a KitchenAid KESS907SSS 30" Slide-In Electric Range with a broken glass cooktop. I have the replacement cooktop and want to do the replacement myself as I live on a remote island. It looks like...
Problem solved. Followed the instructions given and successfully changed the cooktop.
It turned out that the front control panel needed removal in order to access the screws behind it. After that it was clear sailing.
Thanks for your help with this.
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Dacor cooktop Model # SEC30-1C
is this a smooth top? glass? if so gently scrape with a razor blade yes a razor blade. then buff with cerama bryte or comparable cleaner available @ walmart or home depot etc..
Apr 22, 2008 | Dacor Millennia ETT304 Electric Cooktop
Smeg 23 in. SA435X Electric Cooktop Logo
81 people viewed this question
Top Smeg Cooktops Experts
ray gallant
marlin siecinski
Bill Boyd
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
