SOURCE: clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
IT means you need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
You need a new ink absorber box which can be purchased from a brother service partner near your home.
www.brother.com
If you have got the spare part (ink absorber box) you have to open the printer:
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink
anymore and will stain the machine from inside and the furniture
beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
SOURCE: unable to clean 46
Unable to Clean or Machine Error 46 means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET or OK
b. 0 then press SET or OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET or OK
b. 7 then press SET or OK
b. 3 then press SET or OK
This is to reset the purge counter. Then press stop
5. Using arrow up button look for the following:
a. 0 then press SET or OK
b. 1 then press SET or OK (To reset unit)
a. 9 then press SET or OK
b. 9 then press SET or OK (To exit Maintenance mode)
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1.
press buttons Set, Menu, Mono Start one by one, followed by up arrow
key four times. this should all be done as short a time as possible,
around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
