Question about Toshiba 57H81 57" Rear Projection Television
No Picture I was just given this tv for free. I figure whatever is wrong with it will cost less than a new tv, so here goes. There is no picture, and the audio works when a dvd player or something like it is plugged in. The red light is not flashing, no weird popping or clicking either.
  • 2 more comments
  • Joey Cook May 26, 2009
    I checked everything, and I couldn't find any lack of supply. Could it be my convergence ic's? I would really hate to buy new ones just to find out there isn't any need.
    It'll be a day or two, my dog knocked my flashlight over, and now I fuse F470 is blown. I will have to order one (really sucks having to order such a small part) so I'll get back as soon as I can.
    Out of curiosity, since I have a little time to waste on this now, what outcomes would there be dependent on the supply voltage of the h.o. transistor?
    2.0A 125V
djnick989
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Posted on Mar 02, 2008
  • 7 Answers
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Posted on Sep 18, 2008
SOURCE: TP55Hwon't turn on, after unplugging, click and red light flashes
I HAVE THE SAME PROBLEM ,I FOUND OUT AFTER OBSERVING FOR QUITE SOMETIME THAT THE CLICKING NOISE I HERE AFTER PLUGGING IT TO THE OUTLET CAME FROM A RELAY SWITCH LOCATED ON THE POWER BOARD AFTER TAPPING ON IT THE SET WOULD POWER AND THE BLINKING RED LIGHT GOES TO NORMAL..I BELIEVE THIS RELAY IS CAUSING THIS PROBLEM FOR ALL THE FELLOWS OUT THERE WITH THIS TV SET AND THE BLINKING RED LIGHT..IN MY CASE THE RELAY WENT SO BAD NOW THAT THE COIL THAT MAGNETIZES TO CLOSE THE CIRCUIT GAVE UP ,SO I PULLED THE COVER OF THE RELAY TO UNVEIL THE TWO METAL STRPS THAT COME IN CONTACT AND HAVE BENT ONE SLITELY TO REMANE CLOSE THIS POWERS THE TV UP NORMAL BUT IN ORDER TO SHUT IT DOWN I HAVE TO PULL THE OUTLET. THIS IS TEMPORARY UNTIL I CAN FIND WHERE TO GET RELAY SWITCH. PLEASE DONT TAKE MY RESEARCH AS A SOLUTION BUT FOR WHAT EVER ITS WORTH. I WILL GET THIS UP AND RUNNING AGAIN ITS ALL WORTH EVERY DOLLAR TO FIX.
Posted on Nov 23, 2008
freetek
  • 5568 Answers
SOURCE: when turning on my panasonic cinemavision tv, it
Most likely a power supply failure although the flashing of the LED a fixed number of times may point to something else such as a lamp failure. If you can find a forum for this series, you may find a Panasonic tech who can give you a better read on this.
Posted on Feb 18, 2009
Blurry(ish) picture
nead new picture cartrage
Nov 19, 2009 | Toshiba REGZA 47HL167 TV
TV no longer getting picture, just sound
This is due to a fualty logic board inside and it needs to be replaced, Also the power supply that send the power to this logic board is also suspect since you turn it on it stays on for 2 secouns or so then goes off.
1. Check power supply unit (you may want to dust it out as well, check for buldging capcitors.
2. Check logic board this is what sends signals to the LCD ( we would call it a video card).
3. if you cannot do this yourself it will not cost much for it to just be looked at and diagnosed before havingto go out a purchase another TV.
Keep in mind I am going by the information you given me and would expect a rating on the information only so please rate Accordenly. :)
It was my pleasure to assist your free question today, I do invite that you chat with one of us experts so we can diagnose live.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Audiovox FPE2306 23 in. LCD Television
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Samsung 46 DLP picture freezes and then....
common problem on samsung. bad DMD BOARD. these are modules located on light-engine. there very proud of this little jewel. usually parts cost 400-500.00 dollars for the shop. after mark-up & labor don't be shocked at 600.00-700.00 repair bill. this is of coarse for dmd replacement. 85-90%. if logic board, est. 400-500.00 repair. mch
Mar 09, 2009 | Samsung DLP HL-P5663W 56" TV
Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Feb 20, 2009 | Sony BRAVIA KDL-40V3000 Television
Sound but no picture
Hello Dabizot,
With the price of the new tv's, I would recommend getting a new tv. It's only a 19" and you can get a flat panel 19" for less than $ 200.00 It may cost you $ 100 plus to get it repaired along with any new parts. If you want to spend less money try looking at the yard sales, people are always selling used TV's for cheap.
Nov 16, 2008 | Neovo AG AG-01 TV Tuner Picture Frame...
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
Sony kv-32v42
Your two options are to take it to a service shop, or the more likely and probably more cost effective option is to purchase a new Television. The newer model will have a far superior picture quality, cost less per inch of viewable area, and likely have more features than your prior T.V. as well.
good luck
May 27, 2008 | Sony KV-32V42 32" TV
No picture but have sound
RDD6 - I had the same problem with my AVT-1498. Took it to the repair shop who told me it would cost hundreds to repair. I figured I could find a replacement crt for less but was wrong - they don't make these tv's anymore, and really don't make any 12v crt's anymore period. So I decided on a 15" 12v ready LCD model which fit the hole where the old crt TV use to be. I needed to rig it to hold the LCD bracket but that wasn't too difficult. Then just hooked the wires back up. Good luck with your situation.
Dec 20, 2007 | Audiovox AVT1498 TV
Has sound, no picture, just color
usually if the tube has gone you will get no sound and all you will get is the telly on standby so the best thing to do is take it to repair shop and they should tell you for free what is wrong but usuall it costs more to repair than it does to buy another one sorry i couldnt be any more help
Oct 29, 2007 | RCA TruFlat 27F520T 27" TV
Toshiba 57H81 57" Rear Projection Television Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
