Question about E-Machines Computers & Internet
Power problem i need to know which pins the power supply need to be connected to for a emachine T3626
  • Art Ellison
    Art Ellison May 11, 2010
    If you are talking about hooking up a power supply to the motherboard, there is one 20 or 24 pin connector and additionally, a second 4 pin connector on most modern machines.
    Is this what you are talking about?
  • Michael Rodriques May 11, 2010
    Are you talking about connection to the motherboard?
SOURCE: need wiring diagram for emachines t2200 motherboard
i need wiring diagram for my emachine t2042! I can't figure out where the red/white, green/white and black/white wires go!
I already know where the power supply wires go, everybody does- they're all the same!
Posted on Oct 11, 2008
  • 42 Answers
SOURCE: eMachine MS-7142 board pin connection diagram needed
easy !!!
this is the manual of your motherboard:
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
note that MS-7142 is actually K8MM-V (as you can see the filename of the manual is: M-7142.zip
Posted on Sep 04, 2009
  • 69 Answers
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Posted on Sep 24, 2009
SOURCE: Motherboard taken out by eMachines Bestec power supply
I have not identified the specific components on the motherboard that blow, but I can tell you the defect in the Bestec supply. The +5 VSB, which is the voltage that is on at all times, loses regulation and climbs to 8-11 volts. I believe this "higher than the required" +5V takes out the components on the motherboard involved with the computer/power supply "turn-on" circuitry. The "on" button on the eMachines front panel no longer turns the motherboard on because the "kept alive when the main power is off circuits" - which allow the on/off button to do its job of turning on the machine - no longer work.
Test your Bestec power supply by plugging it in the wall socket and have it not connected to anything. Read the voltage between the purple wire and any black wire. If you see +5.0V, then this wasn't your problem. If, like it did on mine, is closer to between 8, and 11 V, this is what took out the motherboard.
Posted on Oct 08, 2009
Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
Posted on Feb 22, 2010
My T3626 will only run the fan and the monitor. Thought it was the power supply and purchased a new replacement. Not it! Is this possibly the hard drive? Before I go out and spend what little money I...
try to use only the 24pins or main power connectors and ATX 12volts and without connecting all your hard drives. try to power it. try to use another memory RAM too. second steps try to reset your bios. not successful you have to chage you mother board.
Feb 23, 2011 | E-Machines eMachines Desktop PC
My Emachine T 3626 i got new motherboard, new power supply.new cpu fan and now is not working , i conect everthing but the power lec and power sw dont come out the only way is to turn oof from the...
1) The eMachines T3626 uses an ESC MCP61SM-GM motherboard,
http://support.gateway.com/s//MOTHERBD/Shared/4006233R/4006233Rnv.shtml
Click on > Product Views
Now click on > P- Front Panel Connector
http://support.gateway.com/s/MOTHERBD/Shared/4006233R/4006233Rmvr18.shtml
Did you connect the cables, (Wires), from the Front Panel to the Front Panel Connector, correctly?
Looking at the Front Panel Connector, observe where it has > 2, at the bottom.
(Right above the small round object with the Orange dot in it)
This is the Bottom of the Front Panel Connector
The pins are in Two columns.
The column on the Right side is numbered > Even
The column on the Left side is numbered > Odd
Starting at the Bottom going Up on the Right side,
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going Up on the Ledt side,
Pins 2, 4, 6, 8, and there is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive Activity LED light
B) Pins 5 and 7 are for the Reset switch. (IF one is used)
C) Pin 9 is for the 5+ power
D) Pins 2 and 4 are for the Power On LED light
E) Pins 6 and 8 are for the Power On switch
F) There is NO Pin 10
Let me know in a Comment.
Dec 01, 2010 | E-Machines eMachines Desktop PC
E machine model T3626 Turn on it just whirs--even
this is most likely tye power supply which should be checked -should cure it.
Jun 06, 2010 | E-Machines eMachines Desktop PC
Install a AU31 E machine Motherboard I need to know exactly where each of the tiny power wires go on the motherboard that controls the power.
from the power supply there's a wires with 16 or more pins / connected as 1. insert the in corresponding socket on the motherboard. on the casing there's a wire that has a label of power or power switch. insert that in the motherboard with an indicator power (pins like)
Jun 02, 2010 | E-Machines eMachines Refurbished EMA...
EMachines Power Switch
Rather than hunt for a diagram, take a metal conductor and short out the prongs two at a time until you find the two that turn on your PC. It is 100% safe to do this as you CANNOT damage the motherboard by shorting out the wrong prongs.
Best wishes,
Graemevm
Dec 18, 2009 | E-Machines eMachines Desktop PC
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
EMachines t3626 shuts down at random
You may be dealing with bad or overheating with your processor or memory. If possible, try swapping out your memory chips to see if that does the trick. If not, you will have to try swapping out the processor (much less likely you'll be able to swing that).
Jul 28, 2009 | E-Machines eMachines Desktop PC
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
148 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
