Question about RCA P52960 52" Rear Projection Television
RCA chassis# PTK195Y06B projection tv part
I've been working on a convergance problem on my chassis# PTK195Y06B RCA 52" tv, and I found a blown diode on the main board. The referance designator (printed on the board) is CR705, can anyone give me a part number for this? It's a very small SMT part, and I'm sure its not the whole problem, but I can't tell if my resolders had any effect without this part.
Thanks for the help,
Devon
  • deajohns May 24, 2009
    Thank you for the information, this helps solve the problem. You don't by any chance have a data sheet, or know the ratings of this diode, do you?
    Thanks again,
    -Devon
  • deajohns Jun 21, 2009
    Thanks for the quick response, but after buying the RCA diode from Partstore.com it is the wrong diode. The one that I found is an board mount part on the underside of the power board, the 198589 they sent me was a through hole, matching some on the top side of the board. (I couldn't find any information on this RCA part so I couldn't know it was the wrong part until I bought it)
    Again, the diode I am looking for is CR705 on the underside of the main circuit board. If you know which one this is, or if the Partstore.com has the wrong diode listed?
    Thanks again for the help,
    -Devon Johnson
  • 6,784 Answers
DIODE RCA Part Number: 198589
Posted on May 24, 2009
My 52 inch RCA projection tv has a blue line around everything white
The convergence needs correction. If its not able to be cleared up by running the auto convergence feature in the setu menu then you will need to repair the convergence. You can get free technical assistance and parts foor your RCA at www.tvrepairworld.com they are RCA experts with that chassis
Feb 10, 2013 | RCA R52WM24 52" HDTV Projection Television
The picture looks 3D and when you select the menu all writing is in a U shape. The TV is a RCA HDTV and the model # R52WH74YX51. Serial #G402C10DZ, chassis #ITC222A, and was manufactured Oct. 2006.
Its more than likely the FL231 fuse has blown due to carcked solder joints on the flyback. very famous issue with that model if the auto convergence feature is no longer listed under the setup menu then you will need the convergence option missing repair kit from www.tvrepairworld.com
Aug 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w17 convergence off on 1080i signal only tv works fine with 480p signal.
you will need to adjust the geometry and convergence defaults for both the 1080 and 480 seperately then save. You can get the CD called the ITC222 chassis convergence and alignment CD which shows how to do that from www.tvrepairworld.com
May 26, 2010 | RCA D52W19 52" Rear Projection Television
Hi RCA 52 inch part numbers P52937SG
Tries this website for convergence ICS.Must know how to solder?Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA P52937 52" Rear Projection Television
I have 3d on my 52 inch rca and go to set up convergence isnt there now.is this something i can fix?
Yes its a easy an inexspensive repair. www.tvrepairworld.com has the ITC222 and ITC222A convergence option missing repair kit. The kit contains the parts and CD with instructions.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
RCA 52" Rear Projection P52930BL
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Oct 04, 2007 | RCA P52930BL 52" Rear Projection...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
396 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
