Question about Balboa Instruments Duplex Digital Panel 2 Pump
Coleman 630/632 syst. wiring dia, 1 pump cycles on/off non prog
Ok, the spa overflowed, every thing got wet, when you power up one pump cycles on/off constantly, producing a clicking noise from transformer ? or black elect part. The systm crontrol panel flashes the program routine but does not program. You can turn on/off second pump, but cannot set heat, time, or program, nor stop 1 pump manualy with syst control pannel from cycling on /off. pannel does not turn light on or off. I have a blow dryer trying to dry it out. Previously, the spa would over heat and turn it self off.
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
SOURCE: hi have problem with canadian spa
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Posted on Sep 09, 2011
SOURCE: I have a Balboa Instrument
This is most likely a heater issue. The technician needs todisconnect both heater leads to see if the breaker will hold. This will help you determine where theelectrical problem is occurring and why it is tripping.
You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Posted on Sep 12, 2011
SOURCE: I have a 1999 Emerald
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This soundslike it could be an issue with the board but there is some testing that needsto be done to determine the actual cause. A spa technician will be required tocome out and verify the wiring to the pump and then typically start testingvoltages off of the board as the unit switches between the relays that controlthe speeds on the pump. You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
My coleman eletric fireplace does not work, the fan works but blows cold air instead of hot, what do I do?
There is a fuse located over the heating element in front of the fan. It sits over a small slot above the heating element (probably to cause it to stop working by design). Yes I'm a pessimist. It can be bypassed if it is an emergency by wiring across it. I'm trying to find the replacement fuse now (10amp jet 250v #00575) If you find it please send info to warfalcon23@Gmail.com. I hope we all get our heaters working, for $250 + dollars you'd expect it to last longer than 1 month.
Oct 18, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
What type of oil goes in the pump, and is the tube that comes out of it on the top of the pump supposed to be open or a covered vent??
Hello
10W30 is OK but it must be NON DETERGENT. Be sure you only fill the reservoir 1/3 to 1/2 full. Thee should be a cap on top.
Jul 05, 2009 | Coleman Garden
I have a coleman spa about 4 years old that is leaking, should this be repaired by a plumber or would it take a spa repair person. it is a 6 to 7 person tub coleman horizion
this has to do with where the water is coming from.
1. wall fittitng. just remove it, reseal and replace
2. pump leaking, usually means shaft seal.
3. plumbing fitting. usually just replace the fitting.
4. fiberglass cracked. get a boat repair man and have him fix it. these guys are usually pretty good.
David
May 18, 2009 | Pool & Spa
Wet cloths need help please!!!!!!!
F9=Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Check the drain hose and make sure it is not plugged or inked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check for Drain Pump Failure
Check the Inlet Valve for proper shut off
Check the Pressure switch for proper operation
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Balboa Instruments Duplex Digital Panel 2 Pump Logo
882 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
