Question about HP Compaq Presario V2000z Notebook
Wireless slows when AC power
MY wireless internet connection slows down when I am charging my computer. It works fine when it's running on batteries. I do not have this problem with wifi hotspots....I have done the following: completely re-installed my computer. got a new wireless router. What else can I do? Am I missing something? new wireless card? some settings?
    Scholar:
  • 57 Answers
I apologize, but I honestly can see no correllation between the two, Possibly you can enter bios and disable ACPI (power saving) since the problem occurs only while charging, The problem with this option is that the load will be heavier on your battery, Worth a try even if only to see if it has anything to do with your problem,
I ask that you reply here and let me know the results
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 24, 2009
Slow connection
well for this ,, go to run > type - NCPA.CPL right click on local area connections and click on properties .... a new box will appear with some content on it .... double click on internet protocol version 4 and and copy down all the content if it has ... in a systematic manner
then thrn of the router and unplug all the cables from the back of router and turn of the computer also and wait for 1 minute .... this process is called as Power cycling
ther after one minute connect all the cables back to the router and turn on the computer as well ....
then cee if the problem is resolver or not if it doesn't get threw kindly call your cable operator
..... regards
Apr 19, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
My second computer wont connect to the internet. it was working fine yesterday and my girl shut it down because it was running slow. she turned it back on and it wouldnt connect.
Is it a wireless computer ?
If it is wireless computer then make sure that it is connected to the wireless network .
If ti is connected not connected to the wireless network then you will need to connect to the wireless network.
If it shows it is connected then check the IP address on the computer.
Click Here for more information about the routers and network
Feb 24, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
My computer's wireless internet will not connect... I can hook it directly to router and works but the drivers WILL NOT download and install... What do I do??
Try removing the wireless card.Remove the battery and ac adapter first.The wireless card resides under one of the panel on the rear of the computer.Once removed start the computer again.Remove the drivers installed via Control Panel.Power down reinstall the card.Power up if windows find new hardware install the drivers you download.
Good luck
Nov 10, 2009 | HP Pavilion dv9000z Notebook
I have a dell inspiron 1000 the internet used to work fine on wireless and ethernet it started running slow so i had it cleaned out now it wont connect to the enternet at all. when i click on the view...
Check to see if your Dell is fragmented.
Go to My Computer,
RH click on it,
Go to manage.
Click on disk defragmentor,
If you see alot of red in the chart it is fragmented.
Click the Defragment button and walk away from the computer for at least 30 minutes.
It will max out the cpu and you will not be able to do anything on it.
If it is a laptop make sure the power is connected.
If this does not work,
make sure that the wireless and the wired connection are not running at the same time.
This will slow down the computer.
Mar 11, 2009 | Dell Inspiron 6000 Notebook
Connection
Possibly a Failing Battery...
Remove Your Laptops Battery, And Power On With AC Power alone... Then Try Wireless..
If It Works Again Normally, It's Your Battery Going Dead...
Feb 07, 2009 | NEC Versa VX Notebook
Wireless connection slow
Same problem. RESOLVED it by going to device manager (hold the Windows Logo key near the space bar and hit PAUSE) Click hardware tab, and then device manager. click the plus next to network adapters to expand it, then right click the atheros wireless connection and go to properties. Click advanced, then find the power save mode. click it, then chose turn off on the right.
did this and my wireless is working normal again. hope this helps.
Jan 03, 2009 | Acer Aspire One PC Notebook
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Unable to actually connect to the internet?
Have you tried restarting your router? If not, try unplugging the ac power from the router, wait 30 seconds, and plug it back in. That will usually take care of this problem. If that doesn't work, you can try going into "manage your wireless connections", delete your wireless network from the list, then reconnect to your network.
May 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Unable to connection to wireless connection via battery power
Yes go to you device manager on your computer and select using battery power also. This option is disabled on your wireless card. Once you enable thi restart the computer.
Dec 08, 2007 | Computers & Internet
HP Compaq Presario V2000z Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
