Question about Maytag Performa PAV2200
Removal of Aggitator
How do I remove the Aggitator from a PAV 3200, any ideas?  Thanks.
  • 4,889 Answers
Remove the cap and softener dispenser by pulling it off and locate the agitator bolt. Remove bolt and lift up on the agitator
Posted on Oct 20, 2007
How can I remove the agitator to clean the liquid softner dispenser, it is clogged
you will have to remove plastic nut at top of aggitator to be able to raise the aggitator out of the tub hope this helps
Feb 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I cant lift trhe bottom aggitate plate in my hmwm8000 i have removed the cap and phillips head screw how tov lift the plate?
there should be a bolt holding aggitator on spines,if not try grabbing aggitator and pulling up while rocking aggitator back and forth it will require a great amount of force to remove aggitator fron splined shaft,also so penatrating spray may help sprayed on splined shaft.It also may need to be cleaned around splined shaft to clean built up soap build up. also a haet gun or a hair dryer on high heat on top of aggitator shaft when trying to remove may help!
Jun 12, 2011 | Washing Machines
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
ROGUE ANTIVIRUS SOFTWARE!!
Hello
You can remove it:
Start Taskmanager by pressing Ctrl-Alt-Del
From Prosesse tab, select PAV.EXE and click End Prosess.
Next find and delete following files:
pav.exe
PersonalAntivirus.exe
PersonalAntivirus.lnk
Uninstall Personal Antivirus.lnk
After that I you are familiar with Registy Editor, find and delete
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run “Personal Antivirus
Best regards,
Zizzler
Apr 23, 2009 | E-Machines eMachines Desktop PC
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Dirt like pebbles left in the bottom of the washer after the cycle is complete
take the fabric softener cap off just pull. then look down the middle there will be a bolt 10 mm loosen it and pull the agitater
Jul 22, 2008 | Admiral AW22 Top Load Washer
Aggitator is lose small items (socks) fall down behind aggitator
When the wash plate is loose (can be lifted up and down) it means that your washer needs a u-joint kit. Yes, Whirlpool actually came out with an entire kit for this.
Tightening the bolts (actually there are 6 of them) won't fix your problem. The kit number is 285927. There's an instruction sheet included with it.
After you get the kit and are ready to install it, remove the white plastic dome by inserting a flat screwdriver into the 4 small slots (look closely and you'll see them) and lifting up at the same time.
*Beware... this is a MAJOR job. Be prepared to spend a long time on it. You'll need to lift the top panel, remove the balance ring, remove the wash plate, remove the drive block nut (<---sometimes requires a torch), etc... It may not be something you wanna jump into. Call an appliance repair outfit and ask them what they'd charge to install one if you ordered the part.
Mar 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
104 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
