Dishwashers
Problem for Bosch Dishwashers
Generic problem for all Bosch Dishwashers
Dishwasher smells like fish
By jimandphoebe on May 24, 2009
my bosch dishwasher smells like fish, especially after we have had a fish dinner! i have tried everything... the drain hose is not kinked; the filters are clean. I have used vinegar... it just takes time to dissipate (maybe 2 or three days)
Best Solution
posted on May 24, 2009
Helpful)
blueberry78
Rank: Guru
Rating: 91%, 48 votes
There are several possible causes.
First, make sure the machine is properly installed with the drain hose up in a loop or an air gap before going down to the drain. This is to ensure no dirty water or smells from the sour or garbage disposer backs up into the machine.
Sometimes nasty stuff gets trapped inside internal parts of the machine and inside the sprayer arms. It is normally easy to remove the sprayer arms for cleaning, on reasonably modern Bosch machines they can also be opened up for easy access.
There are also special dishwasher cleaning agents that you can use to perform periodic cleaning cycles. Some believe it is important to use rinse agents to minimize the problem, maybe it is worth trying if you don't use it.
If there is warranty left on the machine I would advise you to complain, there is a slight possibility there is something wrong in the machine for instance bad choice of insulation lining that have been known to emit foul smells.
Good luck with tracking down the cause of this!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
The water will not drain from the dishwasherand the start light is blinking.
Answer
Hoover HEDS 668 dishwasher all four lights flash and beep whilst the machine drains, after a couple... (More)
Answer
my dishwasher won't drain. I've never had any problems before now. My drain isn't clogged so I know... (More)
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
