Question about Magellan Maestro 3140 GPS Devices
Wants to shut down even when plugged in
Even when plugged in, after awhile the screen asks if I want to stay on battery or go to sleep, I want it to stay on and it should not be on battery power as I have it plugged in. It is getting power because it will charge up
    President:
  • 1,111 Answers
This is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise you'll break the unit
Posted on Jun 12, 2009
2 Suggested Answers
  • 1111 Answers
SOURCE: magellan 3140 wants to shut down even when plugged in
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050
most likely the power port is damaged and needs replaced.i have these power ports but often they just need resoldered..i can repair thesemagellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...
to open the case on a 4040 you must start on the powerbutton side, otherwise youll break the unit
Shuts down to black screen
Sounds like it is going into Sleep or Hibernation mode.
In Control panel go to Power options and see what the settings are.
Getting out of sleep mode is accomplished by pressing the power button once.
Mar 22, 2014 | Acer Aspire 5740-6025 Notebook
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Compac pasario c500 on/off light just blinks when I power on computer screen stays blank?
Shut down, unplug, remove battery, plug in, reboot. If it reboots, open Control Panel, Power Options, Advanced power settings, Change Sleep and Hibernate to Never. Adjust the settings to your preference. Set the Screen Saver time. When your laptop is not in use shut it down and unplug, this will prolong life and a reboot everyday will reset your laptop.
Jan 17, 2013 | Computers & Internet
I have problem with my acer aspire one note book, even after shut down i see light on bottom left corner,on screen and, if i remove battery then it goes, and again comes when i connect battery, thanks,...
make sure you are not just selecting sleep option instead of shut down, some comps have the sleep option set where the shut down one is .
hope that helps
Jan 09, 2011 | Acer Aspire One PC Notebook
My computer prompts me to go on hybernate because the battery is not compatible or not installed..
right click on the desktop..go to screen severs ..and there to power savings..in there remove any settings that will get it to sleep and put it never on all the line down ..including on battery mode..and willnot prompt you anymore untill its shuts down from lack of power in battery mode..and will stay on for ever until shut down manually in adapter plugged mode
May 30, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Laptop keeps shutting itself off
Check the power settings - most laptops are set to sleep even if plugged in to AC power - go to Control Panel -> Power Options and check for sleep/shutdown settings under "Plugged In".
Oct 20, 2009 | Computers & Internet
Magellan 3140 wants to shut down even when plugged in
May 29, 2009 | Magellan Maestro 3140 GPS Devices
Does the mouse & keyboard turn off or sleep?
check your windows settings. They are in your power settings. You can adjust your computer to whatever you want.
right click on destop and goto properties, then click on screen savers tab.. see the power settting button now?? You should be able to tell it what to do for everything to do with Power.
Apr 06, 2008 | Logitech Cordless Desktop EX110
Magellan Maestro 3140 GPS Devices Logo
138 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
