Question about Krups XP4030 Espresso Machine
Leaks water in the counter.
Purchased a remanufactured unit and followed the instructions for first time use. It worked well and did all it was supposed to but then I noticed a large puddle of water under it. Picked the machine up and it kept leaking. Took out the tank, dried everything and then filled the tank and put it back and turned it on it started pumping and leaking right away. Will return to the store but wondering if I should try another.
I fixed mine for 25p... you need to take the back off, and the tank holder out (2 screws each). There is a very thin pipe that comes out the pump - that is the leak.
Unclip the little clip and pull out the pipe and fish out the black o-ring out the hole.
Buy a new o-ring and put back together... no leaks =)
Posted on Nov 15, 2009
    President:
  • 1,618 Answers
If you can try to get a Gaggia or Saeco or even a Delonghi.
Posted on May 24, 2009
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
I purchased an expensive $60 kitchen faucet from canadian tire (sku 7783800333092) in toronto ON less than a year back having lifetime limited warranty. Recently it started to have a less flow and then...
Those units some did have problems - please - take a picture of the unit and sent it to the manufacturer - requesting a replacement - this can work wonders.
Apr 11, 2010 | BRASS CRAFT SERVICE PARTS Brass Craft...
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
Jun 02, 2009 | Spidem Trevi Automatic Espresso Machine
While making espreso, the machine leaks water from underneith.
Please email me with your request and I will send you info to fix it.
irene@smithagy.net
it is basically info on removing coffee oils from the Brew Head Screen.
if that does not work you can contact the service center at phone 201-439-1700 or email:
info@electra-craft.com
www.electra-craft.com
Thank you.
Nov 17, 2008 | Briel Domus Due Espresso Machine & Coffee...
Machine will not prime????
I think you have to replace the flow meter (water turbin), it´s like a water counter.
Jul 19, 2008 | Saeco Caffe Charisma Espresso Machine
Krups XP4030 Espresso Machine Logo
907 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
