Question about IBM IntelliStation Z Pro 6221 PC Desktop
Does not start up.
My Comp starts up for 10-15 secs and then shuts down. I have tried everything that i can to solve the problem but it repeats the same process. Can anyone help?
  • 52 Answers
There is some problem in your software so , Plsese right on my computer , choose properties, click on advance tab and you can get there three groups u have have to choose startup and recover and click on setting, just check out the option tat restart computer when error.
ok
i hope then you computer work fine,
Posted on May 24, 2009
    Sergeant:
    Champion:
  • 212 Answers
It is a hard drive issue. reformat the hard drive and reinstall windows
1990 dodge caravan Le,the dash gauges all turn off after 10 sec of starting the van
ALWAYS check the body grounds first. Ground to the dash gages could be faulty, dirty, or just not tight enough to make a good connection.
Aug 25, 2017 | 1991 Dodge Grand Caravan
PASSLOCK 1 STARTS FOR 2 SEC. SHUTS DOWN CHANGED FUEL PUMP,COMP.,IGNITION KEYS &LOCK CYCL. TRYIED THE 10 MIN THING STILL THE SAME
believe it or not, I have heard the instrument cluster to cause problems like this in similar vehicles. Obviously the anti-theft system is actuated. I don't know where the anti-theft module is for sure, but I did have an achieva which changing the cluster solved this same problem.
Sep 04, 2011 | 1997 Chevrolet Cavalier
My comp shuts down at least once a day. i shut it off wait a few sec and start it back up, seems to be good for several hrs. i have run ccleaner and microsoft essentials and they both allways say there is...
it could be a power supply issue.. shut down the computer
remove all connections that go to the power supply , look inside the connectors and inside the mainboard coinnections, make sure there is no corrosion or dust in the connections
use something , like CO2 air can to blow off the dust from the mainboard..
plug all connections back.,. start computer ..if problem persist, it couls be a hardware or s/w compatability issue.
Nov 01, 2010 | Computers & Internet
My computer will not boot up keeps closing down
check how often it shuts down and if it shuts down when you start a particular application then start your computer and go to BIOS and leave it on there ( for example if your comp shuts down every 3 mins in normal mode then leave the comp on for 15 mins in bios to determine if it is a hardware or software issue then check in sfae mode the event log or error reporting if any hardware is causing the issue, update the drivers or try with new user or reinstall OS as last option.
Aug 10, 2010 | Acer Computers & Internet
When i turn my comp on the lights and fans start for about 1 or 2 secs then stops my make of comp is zoostorm
Pleease remove all connections (including Front Panel pin assignments) from Mother Board except Power Supply.
Now find out reset pin assignment on mother board and shot that pin if its woking then again do all connection and try.
other wise dismental complete system and re-assemble sytem. your problem will be solved
Mar 20, 2010 | Computers & Internet
How do I reboot vista laptop in order to remove radial point
a reboot is always a last resort!!! a better option to remove a program is to access control manager by pressing ctrl, atl, delete at the same time. when the prompt window is opened look through both processes and services tabs for anything related to the program hit stop process then just go to start>control panel>add/remove program. if that doesnt work restart your computer in safe-mode. if its a vista hit the power button let it rest for a sec then restart it. since the computer was improperly shut down it will ask if you want to start windows normally. don't instead choose start in safe-mode when it starts everything related to radial point will be shut down making it easy to remove the program through control panel. if you still whish to reboot shut down your computer by opening the start menu and in the lower right corner select restart. when the comp. restarts and the logo appears hit f8 quickly (you only have about 5 seconds before it restarts normally) choose boot with disk insert your start up disk and the computer will restart and all non-default programs will be lost. radial point will finally be defeated but at what cause? at what cause!!!??
Nov 14, 2009 | Microsoft Windows Vista Ultimate Edition
Tv doesn't want to start
The power light blinks about 9 times and the tv wont turn on what does this mean? its a magnavox 51mp392h/17
Aug 05, 2009 | Sony Televison & Video
Comp hardware
Yep thats vista for you,,,
You have to format and rinstall everything,, but before you do
1.) turn it on
2.) wait 12 horus for it to start up
3.) click start then in the ruin box type msconfig
4.,) diablke all services and all atart up programs
5.) Shut down, save changes and pray it works
If that fails then you will have to format and reinstall everything. get it booted back up your files and insert the windows cd. follow the instructions on the screen to do a clean install.
Jul 19, 2008 | Microsoft Windows Vista Ultimate Edition
IBM IntelliStation Z Pro 6221 PC Desktop Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
