When i turned on the machine to do a load of washing it will not fill with water
    Sergeant:
  • 296 Answers
Hi
The water is not getting to the machine? so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem.
OR
chek this site
http://www.doityourself.com/stry/repairwasher
I am sure u will b helpfull
all the best
regards
Posted on May 24, 2009
After washing a load, the next day I find water in bottom of tub in front load.
If it is clean water main couase is a leeky fill valve (not closing) after machine power off. Repalce or turn tap off. If it is hot & cold fill then turn one tap off after a wash and see if the water still comes in. Repeat with the other tap after the next wash.
If it is dirty water then it is filling back up from your drain system this would need to be inspectected for blockage etc.
Oct 01, 2014 | Washing Machines
I have the kenmore elite oasis it turns on and just makes a little noise and counts down the minutes but doesnt fill up drain or spin.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 18, 2011 | Kenmore 24032\24036 Top Load Washer
Hot water doesn't turn on to fill the washer
heatman101
Jan 16, 2011 | Roper RAS6233KQ Top Load Washer
Turn washer on, only get a buzzing sound. No water fill, rotation of agitator, nothing
heatman101
Nov 26, 2010 | Whirlpool LSQ9600L Top Load Washer
Turn machine on,water won't turn on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 10, 2010 | Frigidaire Affinity ATF7000E Front Load...
I put a fairly large load in washer. As the washing started I needed to add an item. I was surprised that the machine had very little water in it. Is there a way to add more water. Also when soaking I had...
The Series 10 and 11 machines have three level fill points the Series 12 and above have two level fill points.
I know Bulky Items wash selection will give you a High water fill which is only 7 inches or so of water in the wash basket. 3.5 inches of water for a medium fill.
You can turn on/open the water inlet valves in Service Mode but I would not recommend that. A manual fill as you did is the only safe way to set the additional water level IMOP.
FAV6800A/FAV9800A Service Manual for reference.
Rich
Jul 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine filling with water while not running
youll need to replace the water inlet valve, its not seating properly after fill, and continues to leak into machine.part number 8181694. in hte ean time you can turn off water supply to machine inbetween wash loads.A good habit to be in anyway.
Mar 17, 2008 | Washing Machines
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
