Question about GE GSL25JFPBS Side by Side Refrigerator
Ice maker problems
I have a 6 month old ge side by side model #gsh25jfxb, that the ice maker freezes up, I just took out the ice basket and the element inside the basket was frozen as well as the area where the ice pops out of.
  • 1,543 Answers
I'm not sure what you are reffering to as an element, but it sounds as if maybe the water valve does not shut off completely and is causing a large blob of ice to form. This can be caused by impurities in the water supply to the refrig, causing the valve to not be able to seal 100% when it should be off. Install a new water inlet valve and put an in-line filter in before the water gets to the refrigerator. As this is generally caused by your water supply (and thus is not a fault of the refrigerator) is really should not be covered under warranty, but most service providers will let that slide and submit a claim if it is within the 12 month warranty period. I'd try a local dealer (in the US, try http://www.geappliances.com/buy/) for fastest service. (if you didn't buy from them, make sure you let them know, and have a copy of the sales receipt to prove date of purchase)
Posted on May 24, 2009
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: ice maker problems
Not sure I understand your problem. If you would like a GE Ice Maker Service Manual I can email you one. Let me know, Sea Breeze
appliancepartsse@yahoo.com
No ice, it has water on door but no ice.
There are two sides to a water control valve. The ice maker side and the water dispenser side. So what I am saying is the problem could be the ice maker side of the dual water control valve. Is there still old ice in the ice maker? If not then pour tap water into ice maker. If after the water freezes and then dumps the ice into the ice bin that will indicate a defective water control valve, If ice maker does nothing but hold old shrinking ice cubes this would mean you have a defective ice maker. Let me know your model number and I will look up the part numbers. I will be here should you have questions, Thanks Sea Breeze
Mar 11, 2013 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Replaced the defrost heater,defrost thermostat,worked good for about 3
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Sep 06, 2017 | GE GSH25JFR Side by Side Refrigerator
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
    Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
    Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
    GE Adora Side by Side Refrigerator Ice maker
    You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
    Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
    Ice maker problems
    May 24, 2009 | General Electric GSH25JFX Side by Side...
    I have a Ge PSW26LSRDSS side by side the water line freezes
    The water line keeps freezing going to the ice maker? The line in the freezer? Is there alot of ice build up around the fan because of this? If so, it sounds like an ice maker malfunction is the root of the problem, and that can cause evap fans to go bad.
    Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice maker problems
    If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
    Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
    I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
    Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
    Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
    there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
    Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
    GE GSL25JFPBS Side by Side Refrigerator Logo
    716 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    richie46
