Question about Uniden Qt206 Thru Hull, Digital Depth Gauge
My depth finder flashes 00.0 I can not get it to work
I got it to set the alarm depth but it won't reset it self to give me true bottom depths
    Problem Solver:
  • 9 Answers
The shallow water sensitivity adjustment is set too far to an extreem. Center the adjustment, then recalibrate at the dock.
Posted on Oct 19, 2009
I lose depth when moving
that's common with all depth finders when on plane you loose bottom lock when you slow down to stop does it start to work again if so you have no problem
Apr 22, 2013 | Garmin GPSMAP 541s
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
Depth finder comes on then goes off
It sounds like some power saver feature on the battery or in the unit. Check with hummingbird, they should have an 800#.
May 12, 2009 | Boating
Problem with navman 4150 fish finder
I installed my Navman 4150 depth finder along with the Navman GPS unit when I purchased my Bayliner Trophy 20Ft. Offshore model. Everything was ok for one year and it has been downhill since then. Losing signal, unbelievable high depth ranges, blank periods, etc.. I now can't even get a reading tieded up at the dock. I am now giving up and shoping for a quality unit.. Cape Disappointment.........
Jan 07, 2009 | Navman Fish 4150sx GPS Receiver
Faria Depth finder
I've found this manuals in Faria's site:
Depth sounder:
http://faria-instruments.com/site_manuals/IS0091F.pdf
Bombardier Depth Sounder:
http://faria-instruments.com/site_manuals/IS0138_C_digital_depth_sounder_owners_manual.pdf
Depth Sounder, Flushmount:
http://faria-instruments.com/site_manuals/IS0141c.pdf
Depth Sounder, Flush Mounted, Remotely Switched:
http://faria-instruments.com/site_manuals/IS0229_A_Digital_depth_sounder.pdf
there are also other useful manuals in the bottom of the page:
http://www.faria-instruments.com/downloads.php
Jul 14, 2008 | Faria Boating
NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Aug 09, 2007 | Garmin 185 Sounder GPS Receiver
Uniden Qt206 Thru Hull, Digital Depth Gauge Logo
758 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Greg Cann
Greg Cann
Mike Marcotte
Mike Marcotte
Are you an Uniden Boating Expert? Answer questions, earn points and help others
