Question about Samsung Washing Machines
Samsung sensor quick800 error code E6
My Washer model is Samsung sensor quick800. During the wash cycle, it washes fine but as long as it goes to spin, it shakes and then beeping and showing error code E6 and then stops. If I skip wash cycle and use rince+spin cycle, most of the time it works fine, but sometime it shows E6 again at spin cycle. There's no error code E6 listed on the manual, I cleaned the filter, and made sure the feet are level'ed with even support. How to solve this problem? Can anyone help me? Thanks!
5 Suggested Answers
  • 2341 Answers
SOURCE: the machine is level. shakes and loud during
you could have a broken shock but most of the time the spider gear is gone,the money it costs to fix it you could by a new washer,that will be up to you to decide
Posted on Oct 31, 2009
SOURCE: Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Posted on Dec 20, 2009
  • 6277 Answers
SOURCE: washing drum shakes and vibrates
Hi from retired Englishman in SW France
You do not say what make and model but the initial cure is the same!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Feb 26, 2011
  • 2341 Answers
SOURCE: my kenmore top loader always
is there rubber on the bottom of the feet?also i've seen in laundry rooms at one time or another the vent line on the dryer popped off or had a hole in it and lint got on the floor and under the washer,it finds it's way under the feet,try tilting the washer back and with a steel brush or sand paper clean off the bottom of the feet and see if that helps,also clean the floor under the washer.you may have to replace the rubbers on the feet.good luck
Posted on Mar 28, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
What does ds mean on Samsung high efficiency washing machine
A dS code means that the door was opened during the cycle. (At least this is true for the WF210ANW/XAA washer.) Close the door tightly and restart the wash cycle.
If the error persists, you probably have a problem with the door latch.
Samsung has the manual and trouble-shooting FAQs for many of their appliances here: http://www.samsung.com/us/support/ . Click on Washers & Dryers (in the rightmost column) then use the drop-down menus to select Washers and then the model.
I hope this helps. Please add a comment with the model of your washer for additional assistance.
Mar 20, 2012 | Samsung Washing Machines
I have error 6E on my samsung washer
If during the spin cycle, the error code could be an error with the printed circuit board assembly of the washer. This means that the temperature readings are incorrect and the error will continue to display.
E6 error code indicates that the water heater is heating water too fast. Press the power button once to clear the error and finish the cycle before repair.
Check this link with additional info: original/457.jpg?1285349415
Hope this helps.
Apr 18, 2011 | Washing Machines
I have a wf206ans machine and today i had error code that looks like (be) or (he) i cant find the manual for this machine .this code appears on all cycles for the machine washing or spinning only . any...
The manual for the WF206ANS is available here: http://downloadcenter.samsung.com/content/UM/200701/20070131100335625_WF317AA_XAA_02291A.pdf . The table with the code list is on page 22 of the pdf (page E-3). A bE error is a motor speed sensor error. If the code reappears when you restart the cycle, then the washer needs service. For other codes or for service, call 1-800-726-7864 (1-800-SAMSUNG).
I hope this helps.
Mar 27, 2011 | Samsung WF206ANS Front Load Washer
Samsung error code 3E?
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 12, 2010 | Samsung WF328AAW Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
220 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
