Question about Westinghouse LTV-32w3 HD Television
Frozen picture and no button response
I turned on my westinghouse LTV-32w3 HD this afternoon after a morning of watching it, as in it worked fine this morning, and the picture is frozen on the HDMI input. I can hear sound but the picture doesn't move. Also, with this problem there is another. The only buttons that respond on the side of the Tv is the power button, as well as on the controller. I can't change input sources, I can't adjust the volume, nor can I mess with the menu, nothing!!
Please help!
john
    Loyalty:
    Visited the website for 30 consecutive days.
  • 110 Answers
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
Posted on May 22, 2017
  • 317 Answers
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Posted on Jun 03, 2008
  • 103 Answers
SOURCE: picture blurry on my Westing house LTV-32w3 HD Television
hi possably is the fan in the back make shour it is working all the time that there is no dust bild up on it stops it from spining it may need a cleen ,or it is a transister heeting up and cooling down the transister is on its way out it will be a hard fix for a tech to fined thay will fined it but it will cost you a heep ,its best to whate till its gon completly .cheers peter
Posted on Apr 05, 2009
  • 3 Answers
SOURCE: my westinghouse lcd tv ltv-32w3 hd
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Posted on May 14, 2009
budmrtn
  • 11361 Answers
SOURCE: I am having problems with my Westinghouse LTV-32w3
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Posted on Jan 04, 2010
  • 92 Answers
SOURCE: Westinghouse Model LTV-32w3 HD goes
The "lvds" cable which is connected to the lcd controller board is taped to the backlight housing and is transmitting interference to the controller board. Remove the tape and pull the cable away from the backlight housing slightly. You will have to remove the mainboard to do this since it is underneath it. Do not touch the power supply or power supply connectors (dangerous high voltage).
Posted on Feb 07, 2010
We have a westinghouse lcd 32w3 hd and when we hooked up a hdmi for the first time the screen went black and no picture or sound, how do we fix this?
If everything but the HDMI is working, its a possibility that the source has a compatibility issue or your TV needs a software/firmware update needed
Aug 01, 2011 | Westinghouse LTV-32w3 HD Television
I have a Westinghouse ltv-32w3 hd, i got scammed when i bought it, the guy who sold it to me showed me the TV, i turned it on when i bought it watched it for awhile and everything was great... Until after...
If you have identified the section or part that is overheating then it relates to an OVERDRIVEN SECTION due to faulty electronics..
In most cases the deterioration of the component value and in this case it can be critical capacitors to the drive that does not train the circuit.
So if you see that a section of the circuit can be instantly cooled using a FREEZE - IT SPRAY, then it will pin point to the faulty device.
Also increasing the heat sink area of a driver can improve but it is better to change the weak components. Also this can be acasecading efffect due to weakness of the components and so change all the suspected components.
Jul 29, 2011 | Westinghouse LTV-32w3 HD Television
I am having problems with my Westinghouse LTV-32w3 HD TV. If flickers and rolls kind of like the old tube tv used to roll and you would have to adjust it in the back by turning the nob. I have a 37 inch...
Nov 25, 2009 | Westinghouse LTV-32w3 HD Television
Get my PIP to work!!!!!!!
The "Picture in Picture" function will only work with a "digital" source like hdmi or dvi input. It will not work with an s-video or vga input source.
Oct 31, 2009 | Westinghouse W32701 27 in. LCD HDTV
Once it's turned on, the screen (picture) starts
Bad LCD controller, see sample here (notes, I remove the cover LCD controller cover to show the board): http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
There are more than one version of the board, you need to match it with the LCD panel number:
Aug 19, 2009 | Westinghouse LTV-32w3 HD Television
Picture blurry on my Westing house LTV-32w3 HD Television
Apr 05, 2009 | Westinghouse LTV-32w3 HD Television
Picture quality
I had the same problem before. I had my wireless router really close to the tv. I relocated the router, and the problem never came back.
Jun 05, 2008 | Westinghouse LTV-32w3 HD Television
Televison & Video Logo
127 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
