Question about Kenmore 79013 Stainless Steel Gas Kitchen Range
Need a manual for Kenmore range model 790.71463703
Too much air in oven burner, flame burns dirty, valve does not seem to adjust adequately.
We would like a manual.
Device is still under warranty.
The instructions said to screw down the valve at the back of the oven. We turned the valve down until it seemed to be seated, but the problem still persisted. So, against all reason, we hunkered down and put some muscle on the wrench ... ah, no cheater pipe, though. The valve turned slightly more than another full twist. That solved the problem.
I am a bit put out that someone at our house misplaced or lost the manual (if it's misplaced, is that lost?). But I am full-fledged pissed off that we have to pay to get support and that there is no online manual, or we have to write an email and then wait a day for a response. In the greed for ever greater exploitation of the consumer, businesses have sold their manuals to "manual.com" and the defenseless consumer must pay to join, pay for the manual, and ... O Lord, what other insults and invisible costs lay in wait for us ... and us so innocent!
However, that being said, I do appreciate your response this AM.
Posted on May 24, 2009
How do I adjust the flame in my gas oven
You have to be careful when adjusting the flame because you can cause carbon monoxide issues. There are two adjustments. the orifice hood and the air shutter. the orifice hood when turned will adjust the flame amount and the air shutter will adjust the burning of the gas. the hood will be on the line feeding the burner usually on them safety valve and should be a 1/2 inch nut. The air shutter is the door like opening on the burner tube itself. Your flame should be a nice blue cone without any yellow and should not blow and walk off the burner.
Oct 05, 2014 | Kitchen Ranges
We have a kenmore 36665 propane gas range/stove. The range burners become very unstable and sometime blow out when the oven turns on. We replaced the main propane regulator and nothing changed. We had...
the oven is leaking
the oven is gas as well? the oven burner when on burns the oxygen in the air if that air travels up oven vent and your exhaust hood pulls it to outside
if your oven door is not closing proper that air gets into burner area the burners as well need air to burn but because this air is now depleted of oxygen the flames start to lift and dance starved for oxygen
you need a service tech
Jan 06, 2018 | Kenmore 36665 / 36669 Gas Kitchen Range
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
May 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
What would cause incomplete combustion on burners and oven?
Look at oven burners while  they are lit. Is the flame coming from all of the holes. If not, see if the piolet or glow coil of ignitor is close enough to that side to make them light.Also make sure holes are not dirty (opened).The flame should be blue with just the tip red . If not adjust the air door to get more air and less gas. Their is also a gas ajustment on the oven gas valve on most. If the flame is jumping out of the hole,too much gas is coming through and you need to adjust the screw to get less gas flow. I hope I understood correctly and this is information that you need.
Dec 14, 2008 | Maytag MGR5770 Gas Kitchen Range
THE JENN AIR BOTTOM BURNER IN THE GAS OVEN IS BURNING YELLOW
check that the bake ignitor is drawing min 3 amps. if not change ignitor. if its ok yellow flame is not enough air for the amount of gas. check the orface(small brass fitting on valve) hole to make sure its clean. if yes adjust air shutter on burner
Nov 16, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Kenmore gas range
You need to turn the orifice on the safety valve down (clockwise) and this will make the flame smaller. The orifice is what the burner for the oven sits on at the bottom. The valve is # 214 on this diagram. http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124111&brandID=0582&modelDesc=GAS%20RANGE&modelNumber=3627331890&documentID=10033508&documentTypeID=PLDM&documentClassCode=PM&titleType=BURNER%20SECTION&titleID=00001&. Hope this helps.
Nov 04, 2007 | Kitchen Ranges
Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Dec 22, 2006 | Kenmore 78673 Gas Kitchen Range
Kenmore 79013 Stainless Steel Gas Kitchen Range Logo
143 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
